can someone help identify my holley carb?
#197276
01/18/09 04:42 PM
01/18/09 04:42 PM
Posts: 423 DFW Texas
AHall
DFW Texas
Re: can someone help identify my holley carb?
[Re: AHall]
#197277
01/18/09 04:57 PM
01/18/09 04:57 PM
Posts: 9,826 las vegas
70AARcuda
las vegas
look on the air horn...the part that sticks up with the choke blade on it..
it will have a List number...
Tony
70 AARCuda Vitamin C 71 Dart Swinger 360 10.318 @ 128.22(10-04-14 Bakersfield) 71 Demon 360 10.666 @122.41 (01-29-17 @ Las Vegas) 71 Duster 408 (10.29 @ 127.86 3/16/19 Las Vegas)
[Re: 70AARcuda]
#197279
01/18/09 05:14 PM
01/18/09 05:14 PM
AHall
DFW Texas
Ok, here #1 or Here #2?
![](http://picsorban.com/upload/carb.id.jpg)
[Re: rrunner]
#197280
01/18/09 05:21 PM
01/18/09 05:21 PM
AHall
DFW Texas
Think you will find it's not the base gasket leaking, but the throttle shaft. The list # will tell what you have, my guess is a 3310 = 750 vacuum secondary
Oh nice, thanks! How does one repair a leaking throttle shaft? ![](/ubbthreads/images/graemlins/beer.gif)
[Re: 1_WILD_RT]
#197284
01/18/09 06:33 PM
01/18/09 06:33 PM
AHall
DFW Texas
Fuel leaking from a throttle shaft is often due to a blown power valve...
List number is in the black box..
Hmmm, ok, where do I find the power valve on this Holley to check that?
I just checked those digits on the flange, and it says, "3310-" -8, or dash B, cant make out that last digit.
[Re: AHall]
#197285
01/18/09 06:36 PM
01/18/09 06:36 PM
70AARcuda
las vegas
remove fuel bowl...and then remove meter block..
it is screw into meter block
the last number would be an 8
Tony
[Re: rrunner]
#197286
01/18/09 06:36 PM
01/18/09 06:36 PM
1_WILD_RT
Management Trainee
Management Trainee
Today? Who Knows?
rruner nails it...
Buy a genuine Holley Renew kit & go throught it... ![](/ubbthreads/images/graemlins/Twocents.gif)
[Re: 1_WILD_RT]
#197287
01/18/09 06:40 PM
01/18/09 06:40 PM
AHall
DFW Texas
If your gonna buy a Speed Demon the first thing you need to do is take it apart to remove machining debris...Besides the Speed Demon is more of a race carb, How much cam & compression are you running? Your combo would likely run better with a Road Demon..
Engle K56 cam stealth aluminum heads on the 440 compression 10:1
So would the road demon be better?
[Re: AHall]
#197290
01/18/09 06:52 PM
01/18/09 06:52 PM
1_WILD_RT
Management Trainee
Management Trainee
Today? Who Knows?
K56 is a pretty mild cam, 224 @ .050 barely more than stock, doubt you'd be wanting a race calibration on the carb...
Road Demon & that CH4B wouldn't be a bad combo, but again all demon carbs are known for dirty assembly so you should tear it apart & clean it before using it...
[Re: 1_WILD_RT]
#197291
01/18/09 06:57 PM
01/18/09 06:57 PM
AHall
DFW Texas
Yea, i was thinking of going to the K-60HYD, would i notice much difference going to that cam?
2360-H K-60HYD .534" .534" 288° 288° .356" .356" 238° 238° 108° $155.00 .904" Lifter profile for Street & Strip hot rod performance, high compression engines power from 2500-6000
[Re: 1_WILD_RT]
#197292
01/18/09 07:00 PM
01/18/09 07:00 PM
AHall
DFW Texas
I just did some research on the road demon and found this--
"Available in 625-cfm and the new 525-cfm and 725 models, the Road Demon™ is perfect for small displacement V8s or V6 engines. The Road Demon™ 625 targets mild performance engines from 302 to 400 cid, and rated at 250-350 horsepower."
on a 440 ci mild performance engine, it would seem I need one step up from the road demon wouldnt it?
[Re: AHall]
#197294
01/18/09 09:00 PM
01/18/09 09:00 PM
1_WILD_RT
Management Trainee
Management Trainee
Today? Who Knows?
Aftee looking over the Barry Grant/Demon website I agree Speed Demon, it's the Mighty Demon I was thinking of...Still I would consider other carbs due to the number of people that have had problems with Demon carbs...Summit quit carrying them due to to many being returned with unhappy customers...
[Re: 1_WILD_RT]
#197295
01/18/09 09:25 PM
01/18/09 09:25 PM
AHall
DFW Texas
Oh yea? What carb would you suggest over the DEMON?
