can someone help identify my holley carb? #197276
01/18/09 04:42 PM
01/18/09 04:42 PM
DFW Texas
AHall Offline OP
AHall  Offline OP
DFW Texas
Need to ID it to order a new gasket since im currently leaking fuel between the carb and intake. Here are the pics, only numbers i can find on it are 5 digits long, cant make out first digit, but remaining are 0569. so X0569. Here are some pics--
Re: can someone help identify my holley carb? [Re: AHall] #197277
01/18/09 04:57 PM
01/18/09 04:57 PM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
look on the air horn...the part that sticks up with the choke blade on it..
it will have a List number...
Tony
70 AARCuda Vitamin C
Re: can someone help identify my holley carb? [Re: 70AARcuda] #197278
01/18/09 05:11 PM
01/18/09 05:11 PM
S.E. Florida, USA
rrunner Offline
rrunner  Offline
S.E. Florida, USA
Think you will find it's not the base gasket leaking, but the throttle shaft. The list # will tell what you have, my guess is a 3310 = 750 vacuum secondary
Re: can someone help identify my holley carb? [Re: 70AARcuda] #197279
01/18/09 05:14 PM
01/18/09 05:14 PM
DFW Texas
AHall Offline OP
AHall  Offline OP
DFW Texas
Ok, here #1 or Here #2?
Re: can someone help identify my holley carb? [Re: rrunner] #197280
01/18/09 05:21 PM
01/18/09 05:21 PM
DFW Texas
AHall Offline OP
AHall  Offline OP
DFW Texas
Oh nice, thanks! How does one repair a leaking throttle shaft?
Re: can someone help identify my holley carb? [Re: AHall] #197281
01/18/09 05:36 PM
01/18/09 05:36 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
Fuel leaking from a throttle shaft is often due to a blown power valve...
List number is in the black box..
Re: can someone help identify my holley carb? [Re: 1_WILD_RT] #197282
01/18/09 05:42 PM
01/18/09 05:42 PM
DFW Texas
AHall Offline OP
AHall  Offline OP
DFW Texas
Im debating on just replacing that Holley with a SPEED DEMON 750 VE pictured here---
Would I notice any difference?
Re: can someone help identify my holley carb? [Re: AHall] #197283
01/18/09 05:54 PM
01/18/09 05:54 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
If your gonna buy a Speed Demon the first thing you need to do is take it apart to remove machining debris...Besides the Speed Demon is more of a race carb, How much cam & compression are you running? Your combo would likely run better with a Road Demon..
Re: can someone help identify my holley carb? [Re: 1_WILD_RT] #197284
01/18/09 06:33 PM
01/18/09 06:33 PM
DFW Texas
AHall Offline OP
AHall  Offline OP
DFW Texas
Hmmm, ok, where do I find the power valve on this Holley to check that?
I just checked those digits on the flange, and it says, "3310-" -8, or dash B, cant make out that last digit.
Re: can someone help identify my holley carb? [Re: AHall] #197285
01/18/09 06:36 PM
01/18/09 06:36 PM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
remove fuel bowl...and then remove meter block..
it is screw into meter block
the last number would be an 8
Tony
Re: can someone help identify my holley carb? [Re: rrunner] #197286
01/18/09 06:36 PM
01/18/09 06:36 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
rruner nails it...
Buy a genuine Holley Renew kit & go throught it...
Re: can someone help identify my holley carb? [Re: 1_WILD_RT] #197287
01/18/09 06:40 PM
01/18/09 06:40 PM
DFW Texas
AHall Offline OP
AHall  Offline OP
DFW Texas
Engle K56 cam
stealth aluminum heads on the 440
compression 10:1
So would the road demon be better?
Re: can someone help identify my holley carb? [Re: AHall] #197288
01/18/09 06:42 PM
01/18/09 06:42 PM
DFW Texas
AHall Offline OP
AHall  Offline OP
DFW Texas
So would a tuned Demon carb show me any kind of difference or not vs. the 3310 im currently running?
Re: can someone help identify my holley carb? [Re: AHall] #197289
01/18/09 06:44 PM
01/18/09 06:44 PM
DFW Texas
AHall Offline OP
AHall  Offline OP
DFW Texas
Ive also got this intake getting bead blasted at the moment- debating where or not to install it. What do you guys think?
Re: can someone help identify my holley carb? [Re: AHall] #197290
01/18/09 06:52 PM
01/18/09 06:52 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
K56 is a pretty mild cam, 224 @ .050 barely more than stock, doubt you'd be wanting a race calibration on the carb...
Road Demon & that CH4B wouldn't be a bad combo, but again all demon carbs are known for dirty assembly so you should tear it apart & clean it before using it...
Re: can someone help identify my holley carb? [Re: 1_WILD_RT] #197291
01/18/09 06:57 PM
01/18/09 06:57 PM
DFW Texas
AHall Offline OP
AHall  Offline OP
DFW Texas
Yea, i was thinking of going to the K-60HYD, would i notice much difference going to that cam?
2360-H K-60HYD .534"
.534" 288°
288° .356"
.356" 238°
238° 108° $155.00
.904" Lifter profile for Street & Strip hot rod performance, high compression engines power from 2500-6000
Re: can someone help identify my holley carb? [Re: 1_WILD_RT] #197292
01/18/09 07:00 PM
01/18/09 07:00 PM
DFW Texas
AHall Offline OP
AHall  Offline OP
DFW Texas
I just did some research on the road demon and found this--
"Available in 625-cfm and the new 525-cfm and 725 models, the Road Demon™ is perfect for small displacement V8s or V6 engines. The Road Demon™ 625 targets mild performance engines from 302 to 400 cid, and rated at 250-350 horsepower."
on a 440 ci mild performance engine, it would seem I need one step up from the road demon wouldnt it?
Re: can someone help identify my holley carb? [Re: 1_WILD_RT] #197293
01/18/09 07:07 PM
01/18/09 07:07 PM
Rio Linda, CA
John_Kunkel Online content
John_Kunkel  Online Content
Rio Linda, CA
A blown power valve would drip below the throttle shafts, directly into the intake plenum.
Re: can someone help identify my holley carb? [Re: AHall] #197294
01/18/09 09:00 PM
01/18/09 09:00 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
Aftee looking over the Barry Grant/Demon website I agree Speed Demon, it's the Mighty Demon I was thinking of...Still I would consider other carbs due to the number of people that have had problems with Demon carbs...Summit quit carrying them due to to many being returned with unhappy customers...
Re: can someone help identify my holley carb? [Re: 1_WILD_RT] #197295
01/18/09 09:25 PM
01/18/09 09:25 PM
DFW Texas
AHall Offline OP
AHall  Offline OP
DFW Texas
Oh yea? What carb would you suggest over the DEMON?
