Page 1 of 8 1 2 3 4 5 6 7 8
What front-end system system would you go with? #1972361
12/18/15 10:47 PM
12/18/15 10:47 PM
PA.
pittsburghracer Online work OP
"Little"John
pittsburghracer  Online Work OP
"Little"John
PA.
Thinking about possibly changing the front end suspension on the 74 Duster I picked up this year. Its a full cage (app 3000 pounds with big block). Car was already raced with a big block but we each kept our drivetrain so I am build a mega block 512 for it with hopes of running 8's in the car. Kinda spoiled by the ease of working on my other cars with struts and rack and pinion steering so I would like to get rid of the k member, tortion bars, and straighten out the steering issues with stock mopar systems. The car already has Wilwood brakes on mopar spindles so I would like to be able to reuse those if possible. This subject has been talked about often but new changes are always coming out. What system would you go with and why. I will be buying a set of Andys big block and small block engine plates so I can run both combos.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: What front-end system system would you go with? [Re: pittsburghracer] #1972403
12/18/15 11:34 PM
12/18/15 11:34 PM
Janesville, WI
SpareParts Offline
SpareParts  Offline
Janesville, WI
I would do a strut front end. Cost is probably less than the beating 5hey give us mopar guys on K members. You can sell the brakes and spindles for a head start on cost.
There's times I wish I was a fox body guy, a world of $200-500 used front ends everywhere
Re: What front-end system system would you go with? [Re: pittsburghracer] #1972405
12/18/15 11:35 PM
12/18/15 11:35 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
If you trim the K-frame the pan will come right off with the drag link pulled. If you drill the outer tie rod locations, idler arm and pitman arm holes in the drag link you can insert tapered spacers in the holes. Now the entire steering linkage comes off with 4 nuts. The headers don't appear to be an issue. What steering issues, bump steer? caster? easily fixed. This would be my cheap solution.
Doug
Re: What front-end system system would you go with? [Re: dvw] #1972413
12/18/15 11:52 PM
12/18/15 11:52 PM
Lynchburg, VA
Leon441 Offline
Leon441  Offline
Lynchburg, VA
Bobsprofab
Re: What front-end system system would you go with? [Re: dvw] #1972439
12/19/15 12:36 AM
12/19/15 12:36 AM
PA.
"Little"John
"Little"John
PA.
Doug
I really like this idea as with other projects it would keep costs down. What do you think of this system Doug as I could get rid of the tortion bars, use my brakes, free up some room, and have some more adjust-ability. I would still have to deal with bump steer but from the way you sound its doable.
http://www.gerstsuspensions.com/coil-over-conversion-kit.html
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: What front-end system system would you go with? [Re: pittsburghracer] #1972442
12/19/15 12:39 AM
12/19/15 12:39 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Strange struts.. comes with everything
except the rack... $1800-$2000 depending
on what size you want... thats brakes and all
wave
Re: What front-end system system would you go with? [Re: MR_P_BODY] #1972443
12/19/15 12:43 AM
12/19/15 12:43 AM
nc
E
earthmover Offline
earthmover  Offline
E
nc
I have a friend that has struts rack and all except brakes that he wants to sell ..plans changed and went with a a arm set up for street use..if you like to pm me ill give you his info might be a deal for you ..I don't really know so wouldn't hurt to talk to him about it
Re: What front-end system system would you go with? [Re: Leon441] #1972457
12/19/15 01:07 AM
12/19/15 01:07 AM
Lubbock,TX
DavidDean Offline
DavidDean  Offline
Lubbock,TX
Originally Posted By Leon441
Bobsprofab
I agree that's what I have . Very nice piece . A friend here in Texas saw mine and got one for his Dart.
Re: What front-end system system would you go with? [Re: pittsburghracer] #1972466
12/19/15 01:17 AM
12/19/15 01:17 AM
Charlotte, North Carolina
sgcuda Offline
sgcuda  Offline
S & W, ART have front end frame kits, with Strange struts and steering rack for around $2,500. I'm considering this mod, myself.
[image][/image]
Re: What front-end system system would you go with? [Re: pittsburghracer] #1972494
12/19/15 01:52 AM
12/19/15 01:52 AM
MI, usa
dvw Offline
dvw  Offline
MI, usa
Doug
Not familiar with them. Doesn't look bad from a glance. I can tell you the torsion bars really haven't been an issue for me. If they bother you and you have to buy shocks anyway then I could see this kit as an option. My car has offset control arm bushings, less than a $100 in modified strut rods, tie rod sleeves, and heims. It drives straight at 150mph and front suspension is square. Just took a little effort, but pretty straight forward. This shot shows how square the front stays.
Doug
Re: What front-end system system would you go with? [Re: dvw] #1972510
12/19/15 02:19 AM
12/19/15 02:19 AM
PA.
"Little"John
"Little"John
PA.
Doug
Doug
That car looks and runs GREAT. Nice job on the front suspension. When I get a chance and an empty bay in my shop I will move this car over and check the front end out. Thanks for the sugestions
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: What front-end system system would you go with? [Re: pittsburghracer] #1972592
12/19/15 12:03 PM
12/19/15 12:03 PM
Richmond, Tx. (Houston)
GTSDave Offline
GTSDave  Offline
I still have basically stock, with a trimmed K-Member in the Cuda. Tubular uppers and lowers. Torsion bars are still in place but headers are a pain as I run a 4 speed. Looking to replace the ProParts headers on there now and was getting ready to build new ones but space is an issue...... Since I run NSS with the Cuda, I must stay with stock. The exception is the control arms, as long as they are bolt in replacements. It does drive VERY well though and I have no complaints there. For me the advantage with the rack with struts would be having room to work on everything. Space is tight in my car.
By the way, what headers are in this pic?
-Dave
PLEASE Pray for our brothers and sisters in harms way.
If you are the owner of a GTS us at the GTS Registry www.gtsregistry.com
Re: What front-end system system would you go with? [Re: pittsburghracer] #1972631
12/19/15 01:24 PM
12/19/15 01:24 PM
baldwinsville new york
a493demon Offline
a493demon  Offline
i'll try and post a pic of a k-frame I have with tubular lowers on it .
I have been thinking about switching from my bone stock set up for years just haven't yet.
Re: What front-end system system would you go with? [Re: GTSDave] #1972652
12/19/15 01:58 PM
12/19/15 01:58 PM
PA.
"Little"John
"Little"John
PA.
-Dave
Dave I texed the previous owner to make sure on the headers. They are TTI 2- 2 1/8 stepped header
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: What front-end system system would you go with? [Re: a493demon] #1972655
12/19/15 02:00 PM
12/19/15 02:00 PM
PA.
"Little"John
"Little"John
PA.
Thank-you. I would appreciate that.
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: What front-end system system would you go with? [Re: pittsburghracer] #1972659
12/19/15 02:01 PM
12/19/15 02:01 PM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
More room for the WIN!! laugh2.... appears PBR has "upgraded" for a lot of the same reason I did... ease of making things fit!
I will say, can handles a ton better than it did, easy to adjust front end... can even increase roll out by adjusting lca. Mike at Comp Chassis in Phoenix did this up for me.
Re: What front-end system system would you go with? [Re: pittsburghracer] #1972664
12/19/15 02:12 PM
12/19/15 02:12 PM
Morrow, OH
markz528 Offline
markz528  Offline
Morrow, OH
I went with the Alterkation for my 67 Coronet. Was able to reuse my Wilwood brakes even though Wilwood competes for being one of the most slimeball companies on earth..............
Re: What front-end system system would you go with? [Re: J_BODY] #1972665
12/19/15 02:14 PM
12/19/15 02:14 PM
PA.
"Little"John
"Little"John
PA.
Room is nice and it will spoil you real quick. This car I'm looking for a few other reasons to. Most tracks rules dictate a diaper on 8 second cars, adding the mega block weight on an already heavier A body, and fast footbrake cars need ways to slow down the hit on bottom bulb racing so adjust-ability is needed. Us 60 years olds like to make things easier when we work on our cars by ourselves AND on the floor. LOL
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: What front-end system system would you go with? [Re: markz528] #1972668
12/19/15 02:19 PM
12/19/15 02:19 PM
PA.
"Little"John
"Little"John
PA.
I was doing some reading on this set-up in the tech archives but it was an older post. Seems guys either love it or hate it but I'll try to dig up some newer info on this company. Having the Wilwood brakes already and being able to still use them would be a big help in keeping costs down.
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: What front-end system system would you go with? [Re: pittsburghracer] #1972733
12/19/15 04:14 PM
12/19/15 04:14 PM
St.Louis, Mo.
mokid Offline
mokid  Offline
St.Louis, Mo.
I can tell you who not to go to, Don't go to High Speed Welding in Chicago they are clueless, don't go to Andy McCoy Chassis in Washington Mo. unless you want your front wheels to break off mid-track,
