Re: Need Carburetor Help 66 Fury 383 with BBD
[Re: Powerflow]
#1972391
12/18/15 11:18 PM
12/18/15 11:18 PM
RapidRobert
I would call your parts house & have them pull the # for the kit listed for a '66 383 carter BBD 2bbl & see the years it covers but I think the odds are that there is quite a spread there & that a kit for a '66 would cover your carb even if it ain't original (& I'm thinking that it is). You could just install the new needle/seat out of the kit (have the top off) & they interchange no matter what year) then recheck/set the float level as needed (might be 1/4" iirc), the white sheet (& your buddy) will help you. clean the carb base and the manifold base and a new base gasket (will be in the carb kit) & reinstall the carb/lines/hoses/linkage etc. I like to lube the top bowl screws that secure the top to the main carb body (actually any screws that go into aluminum). open the throttle all the way then spray the carb throat with starting fluid then shut the throttle & crank it. EDIT the needle/seat assy is brass so "reasonably" tight on that
[Re: RapidRobert]
#1972474
12/19/15 01:31 AM
12/19/15 01:31 AM
Posts: 1,841 South Bend
John Brown
South Bend
The big differences over the years was the shape of the accelerator pump shaft/rod. If you can match that up, you will most likely be home free. When I was working parts counter, we had a carb guy down the road that was always bringing in odd carbs and parts in to match up. 99 % of the time, he left with something that would work.
[Re: Powerflow]
#1972503
12/19/15 02:06 AM
12/19/15 02:06 AM
Posts: 104,346 Garden Grove, CA
OzHemi
Penguin-hating Ginger
Garden Grove, CA
That doesn't look like a BBD ? Looks more like a WWC Stromberg And it would be worth pulling it right apart and rebuilding it completely in my opinion if you are having any issues with it...that way you can blow out and clean out all of the passages, etc in it. Kits are pretty cheap and not hard to do!
[Re: OzHemi]
#1972518
12/19/15 02:51 AM
12/19/15 02:51 AM
RapidRobert
That doesn't look like a BBD ? Looks more like a WWC Stromberg Oz I think you are right. OP if you are sure there ain't no (good) number on it I'd still suggest askin what the parts house has to provide for a range of years of WWC apps for ~66 383's & other size engines in that range as needed. Yes it definitely would be better to soak it especially after all those years idle. Carb cleaner ain't stout like it used to be (EPA regs) but you can get a gallon & set the carb in a container & fill up the bowl & let it set so the fluid gets to all the innards & the cluster might fit in the carb bowl to make it even easier. I would not remove the jets
[Re: racerhog]
#1972574
12/19/15 11:11 AM
12/19/15 11:11 AM
Posts: 75,062 U.S.S.A.
JohnRR
U.S.S.A.
No...Its a Carter BBD..... Sorry , that is not a carter BBD , this is ...
[Re: racerhog]
#1972661
12/19/15 02:06 PM
12/19/15 02:06 PM
Posts: 4,275 Morrow, OH
markz528
Morrow, OH
No...Its a Carter BBD..... It is a Carter BBD. Below are pics of my 65 Fury Carter 4125S BBD Carb.
[Re: Powerflow]
#1973634
12/21/15 02:45 AM
12/21/15 02:45 AM
Posts: 125 Iowa
dsp
Iowa
Powerflow's carburetor is a Carter BBD, not a Stromberg WWC. The BBD came in two sizes: 1-1/4" venturi or 1-1/2" venturi. Small blocks used the BBD 1-1/4" and big blocks used the BBD 1-1/2". A 1966 383 would have been equipped with a Stromberg WWC. The 1966 361 was equipped with a BBD. Powerflow's carburetor is a 1968 or later unit because it has the hole in the throttle lever for a cruise control lost motion link.
