Powervalves
#197209
01/18/09 03:12 PM
01/18/09 03:12 PM
Posts: 6,295 U.S.
moparniac
U.S.
i dont have one in my Dominator carb but If I do run one what about jetting.... I read my holley book but its a book. rather hear what you guys have done...
90's squared pri shooter .035 sec shooter .035 idle feeds .035 bleeds .045 idle / .075 mid / .035 main
street car 3800lbs changes were 3.91 28" tire to 4.10's 30" tire 11" converter to 9" custom converter Eddy rpm's stage 3 to Indy CNC's 295's 8 3/4 to Dana 60 TM7 with 4500 adapter to Indy 440-3
SS springs to caltracs CE stuff to Ranchos / front calvert shocks
93 pump gas car
I listed this stuff so someone wouldnt ask
Mopar Performance
Re: Powervalves
[Re: Thumperdart]
#197211
01/18/09 03:21 PM
01/18/09 03:21 PM
Posts: 6,295 U.S.
moparniac
U.S.
also where do you guys hook up your vacuum guage to? got any pics also?
thx
Mopar Performance
Re: Powervalves
[Re: moparniac]
#197212
01/18/09 03:37 PM
01/18/09 03:37 PM
dartman366
Mt. Vernon, Ohio
A lot depend's on what your power valve channel restricter is in your metering block, mine were .082 and I ended up jetting way down in the front, because when the PV opens the jet size and PVCR are added together to give you the fuel that the motor see's, seem's like I jetted down about 13 size's in the front when I put the PV in,,,B1KEN had a chart that showed the fuel flow of the jet's and a formula that did the same for the PVCR,I have stuck to that info and it has worked good for me,,,,as far as a vac gauge I drilled and tapped a hole and added a fitting to the spacer under my carb. ![](/ubbthreads/images/graemlins/thumbs.gif)
Re: Powervalves
[Re: moparniac]
#197213
01/18/09 03:55 PM
01/18/09 03:55 PM
Thumperdart
State of confusion
I have a port on my adapter/spacer that I hook a gauge up to although w/ big cams, a 2.5-3.5 gets the job done. ![](/ubbthreads/images/graemlins/Twocents.gif)
Re: Powervalves
[Re: Thumperdart]
#197214
01/18/09 05:09 PM
01/18/09 05:09 PM
dartman366
Mt. Vernon, Ohio
That's where I ended up with my PV,,,3.5
Re: Powervalves
[Re: Thumperdart]
#197217
01/18/09 05:28 PM
01/18/09 05:28 PM
Quicktree
I ended up w/90`s in the ft. w/a 3.5 pv and 99`s in the rear on my hp 1050 8082-3 dommy and it was chassis dynoed and has gone faster than ever this way. I usually jet down 8-10 sizes when using a pv.
how muc vac do you have at idle in gear?
Re: Powervalves
[Re: The Avg. Valiant]
#197218
01/18/09 05:29 PM
01/18/09 05:29 PM
Quicktree
I just took my intake vacuum, divided by 2 and there was my PV number. This is what I was told to do by 2 old time guys, not sure if its true but its worked so far.
thats not the way you do it ![](/ubbthreads/images/graemlins/tsk.gif)
Re: Powervalves
[Re: Quicktree]
#197220
01/18/09 08:41 PM
01/18/09 08:41 PM
Thumperdart
State of confusion
Quicktree, I have about 5 1/2-6"`s at idle and bet 10-11 cruising.
Re: Powervalves
[Re: Quicktree]
#197221
01/18/09 09:06 PM
01/18/09 09:06 PM
Posts: 1,091 Col. Ohio
The Avg. Valiant
Col. Ohio
Im all ears(im just running a 750 with vacuum secondaries, so I to am interested in how to set this as I dont have a DOM)
Re: Powervalves
[Re: Thumperdart]
#197226
01/18/09 10:58 PM
01/18/09 10:58 PM
Quicktree
then your PV should a 41/2 to 5
