Page 1 of 3 1 2 3
Powervalves #197209
01/18/09 03:12 PM
01/18/09 03:12 PM
U.S.
moparniac Offline OP
U.S.
i dont have one in my Dominator carb but If I do run one what about jetting.... I read my holley book but its a book. rather hear what you guys have done...
90's squared
pri shooter .035
sec shooter .035
idle feeds .035
bleeds .045 idle / .075 mid / .035 main
street car 3800lbs
changes were 3.91 28" tire to 4.10's 30" tire
11" converter to 9" custom converter
Eddy rpm's stage 3 to Indy CNC's 295's
8 3/4 to Dana 60
TM7 with 4500 adapter to Indy 440-3
SS springs to caltracs
CE stuff to Ranchos / front calvert shocks
93 pump gas car
I listed this stuff so someone wouldnt ask
Mopar Performance
Re: Powervalves [Re: moparniac] #197210
01/18/09 03:17 PM
01/18/09 03:17 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
I ended up w/90`s in the ft. w/a 3.5 pv and 99`s in the rear on my hp 1050 8082-3 dommy and it was chassis dynoed and has gone faster than ever this way. I usually jet down 8-10 sizes when using a pv.
Re: Powervalves [Re: Thumperdart] #197211
01/18/09 03:21 PM
01/18/09 03:21 PM
U.S.
U.S.
also where do you guys hook up your vacuum guage to? got any pics also?
thx
Mopar Performance
Re: Powervalves [Re: moparniac] #197212
01/18/09 03:37 PM
01/18/09 03:37 PM
Mt. Vernon, Ohio
dartman366 Offline
dartman366  Offline
Mt. Vernon, Ohio
A lot depend's on what your power valve channel restricter is in your metering block, mine were .082 and I ended up jetting way down in the front, because when the PV opens the jet size and PVCR are added together to give you the fuel that the motor see's, seem's like I jetted down about 13 size's in the front when I put the PV in,,,B1KEN had a chart that showed the fuel flow of the jet's and a formula that did the same for the PVCR,I have stuck to that info and it has worked good for me,,,,as far as a vac gauge I drilled and tapped a hole and added a fitting to the spacer under my carb.
Re: Powervalves [Re: moparniac] #197213
01/18/09 03:55 PM
01/18/09 03:55 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
I have a port on my adapter/spacer that I hook a gauge up to although w/ big cams, a 2.5-3.5 gets the job done.
Re: Powervalves [Re: Thumperdart] #197214
01/18/09 05:09 PM
01/18/09 05:09 PM
Mt. Vernon, Ohio
dartman366 Offline
dartman366  Offline
Mt. Vernon, Ohio
That's where I ended up with my PV,,,3.5
Re: Powervalves [Re: dartman366] #197215
01/18/09 05:15 PM
01/18/09 05:15 PM
U.S.
U.S.
my current cam is 248/254 @ 50 solid roller....
Mopar Performance
Re: Powervalves [Re: moparniac] #197216
01/18/09 05:28 PM
01/18/09 05:28 PM
Col. Ohio
The Avg. Valiant Offline
Col. Ohio
I just took my intake vacuum, divided by 2 and there was my PV number. This is what I was told to do by 2 old time guys, not sure if its true but its worked so far.
Re: Powervalves [Re: Thumperdart] #197217
01/18/09 05:28 PM
01/18/09 05:28 PM
Q
Quicktree Offline
Quicktree  Offline
Q
how muc vac do you have at idle in gear?
Re: Powervalves [Re: The Avg. Valiant] #197218
01/18/09 05:29 PM
01/18/09 05:29 PM
Q
Quicktree Offline
Quicktree  Offline
Q
thats not the way you do it
Re: Powervalves [Re: Quicktree] #197219
01/18/09 07:20 PM
01/18/09 07:20 PM
U.S.
U.S.
Mopar Performance
Re: Powervalves [Re: Quicktree] #197220
01/18/09 08:41 PM
01/18/09 08:41 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Quicktree, I have about 5 1/2-6"`s at idle and bet 10-11 cruising.
Re: Powervalves [Re: Quicktree] #197221
01/18/09 09:06 PM
01/18/09 09:06 PM
Col. Ohio
Col. Ohio
Im all ears(im just running a 750 with vacuum secondaries, so I to am interested in how to set this as I dont have a DOM)
Re: Powervalves [Re: The Avg. Valiant] #197222
01/18/09 09:54 PM
01/18/09 09:54 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
I`ve heard about the divide your total vac in half theory also and who knows. For the longest time I ran a 2.5 but was told they can actually shudder off and on(open and closed)so I installed the 3.5 but can`t say for sure if it helped or not. If it`s a race deal and lets say you have 6" in gear I would run a 3.5 or a 4.5 myself. Then there`s the economy tuning but who needs that.
Re: Powervalves [Re: Thumperdart] #197223
01/18/09 10:12 PM
01/18/09 10:12 PM
U.S.
U.S.
what do you have at WOT ....
Mopar Performance
Re: Powervalves [Re: moparniac] #197224
01/18/09 10:15 PM
01/18/09 10:15 PM
U.S.
U.S.
isnt idle supposed to be around 20 ???
Mopar Performance
Re: Powervalves [Re: moparniac] #197225
01/18/09 10:21 PM
01/18/09 10:21 PM
U.S.
U.S.
this video says divide by 2 ???
http://www.youtube.com/watch?v=6vKlAnKdcB4
Mopar Performance
Re: Powervalves [Re: Thumperdart] #197226
01/18/09 10:58 PM
01/18/09 10:58 PM
Q
Quicktree Offline
Quicktree  Offline
Q
then your PV should a 41/2 to 5
Re: Powervalves [Re: The Avg. Valiant] #197227
01/18/09 11:41 PM
01/18/09 11:41 PM
AndyF Offline
AndyF  Offline
Intake vacuum divided by 2 should work fine. If the idle vacuum is higher than 12 inches then use a 6.5.
Re: Powervalves [Re: AndyF] #197228
01/18/09 11:44 PM
01/18/09 11:44 PM
wisconSIN
Blown61 Offline
Blown61  Offline
wisconSIN
Why not put a vac gauge on it and map where it is during cruise and wot then you can put in a pv with a lit lower rate to stay shut until you need it?
Page 1 of 3 1 2 3
