Re: A body with small block - best headers ??
[Re: urdustd]
#1971887
12/18/15 01:33 AM
12/18/15 01:33 AM
Posts: 1,390 CA.
RAY1969CARS
CA.
BTW I run a Summit cast deep trans pan. Do you have a picture of that pan
[Re: urdustd]
#1971919
12/18/15 02:17 AM
12/18/15 02:17 AM
Posts: 52,972 Romeo MI
MR_P_BODY
You hit file manager at the bottom of the text box.. then hit browse.. when you get it on your computer double click the pic.. then hit add pic then hit done.. hit submit
[Re: indcontrols]
#1972258
12/18/15 06:40 PM
12/18/15 06:40 PM
Posts: 4,457 Washington
madscientist
Washington
Lose the power steering. Then order a set of 5204 Hookers.
[Re: madscientist]
#1972304
12/18/15 08:50 PM
12/18/15 08:50 PM
Posts: 2,697 Renton Wa
topfueldart
Renton Wa
Loved the TTI's I had on my car. Install from the bottom as directed, and they are a breeze, with great ground clearance.
11.48 @ 120 with a 1.80 60' 318, stock 1.88 heads, stock 904, Pump Gas, 13 lbs of boost.
9.94 @ 134, 318 on pump gas, 14 lbs w/ Eddies, transbrake 727, 3600 lbs, 3.54 gear and 28's.
