A body with small block - best headers ?? #1971854
12/18/15 01:02 AM
12/18/15 01:02 AM
South Florida
indcontrols Offline OP
South Florida
My buddy has a 74 Duster with a 360 with 340 heads, it has power steering and power brakes. The headers he has now give zero ground clearance. What's the best solution for decent money ??
Re: A body with small block - best headers ?? [Re: indcontrols] #1971863
12/18/15 01:12 AM
12/18/15 01:12 AM
River Falls, WI
urdustd Offline
urdustd  Offline
River Falls, WI
You have two choices, Doug's D453 and TTI. Doug's are cheaper, TTI are step Headers. I guess you can also do Hooker super comps too. I have Doug's on my 1974 Duster 360 and they fit great. I have PS and PB with auto trans.
Re: A body with small block - best headers ?? [Re: indcontrols] #1971864
12/18/15 01:14 AM
12/18/15 01:14 AM
South Florida
South Florida
Awesome - thanks !!!! I'll look into the Doug's
Re: A body with small block - best headers ?? [Re: indcontrols] #1971865
12/18/15 01:15 AM
12/18/15 01:15 AM
South Florida
South Florida
How's your ground clearance ?
Re: A body with small block - best headers ?? [Re: indcontrols] #1971867
12/18/15 01:17 AM
12/18/15 01:17 AM
CA
crackedback Online content
crackedback  Online Content
CA
Dougs from autozone with the 20% discount code they run almost every month. Can't beat the price.
Re: A body with small block - best headers ?? [Re: indcontrols] #1971874
12/18/15 01:23 AM
12/18/15 01:23 AM
River Falls, WI
urdustd Offline
urdustd  Offline
River Falls, WI
They are over chassis and dont trap the suspensioñ like the cheap ones. Let me put it this way, my exhaust is now higher up then my transmission pan!
Re: A body with small block - best headers ?? [Re: indcontrols] #1971879
12/18/15 01:25 AM
12/18/15 01:25 AM
South Florida
South Florida
That's freaking awesome - thanks !!!
Re: A body with small block - best headers ?? [Re: indcontrols] #1971880
12/18/15 01:25 AM
12/18/15 01:25 AM
River Falls, WI
urdustd Offline
urdustd  Offline
River Falls, WI
BTW I run a Summit cast deep trans pan.
Re: A body with small block - best headers ?? [Re: urdustd] #1971887
12/18/15 01:33 AM
12/18/15 01:33 AM
CA.
RAY1969CARS Offline
RAY1969CARS  Offline
CA.
Do you have a picture of that pan
Re: A body with small block - best headers ?? [Re: RAY1969CARS] #1971904
12/18/15 02:05 AM
12/18/15 02:05 AM
River Falls, WI
urdustd Offline
urdustd  Offline
River Falls, WI
I haven't tried posting pics with the new board so hopefully this works...
Re: A body with small block - best headers ?? [Re: indcontrols] #1971907
12/18/15 02:08 AM
12/18/15 02:08 AM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
have one of those pans laying around.... just because I prefer the deep steel pans.
Re: A body with small block - best headers ?? [Re: urdustd] #1971908
12/18/15 02:08 AM
12/18/15 02:08 AM
River Falls, WI
urdustd Offline
urdustd  Offline
River Falls, WI
Here's a couple more pics
Re: A body with small block - best headers ?? [Re: J_BODY] #1971915
12/18/15 02:13 AM
12/18/15 02:13 AM
River Falls, WI
urdustd Offline
urdustd  Offline
River Falls, WI
The price of the pan was right and it is pretty well made. My stock pan was in tough shape, so I figured a little more fluid could only help. Also figured the aluminum would dissipate heat a little quicker than steel which could only help here in the desert
Re: A body with small block - best headers ?? [Re: urdustd] #1971919
12/18/15 02:17 AM
12/18/15 02:17 AM
MR_P_BODY Offline
MR_P_BODY  Offline
You hit file manager at the bottom of the text
box.. then hit browse.. when you get it on your
computer double click the pic.. then hit add pic
then hit done.. hit submit
wave
Re: A body with small block - best headers ?? [Re: MR_P_BODY] #1971925
12/18/15 02:26 AM
12/18/15 02:26 AM
River Falls, WI
urdustd Offline
urdustd  Offline
River Falls, WI
Thanks Mr P. I figured out a way, but nearly as simple. Learn something new everyday!
Re: A body with small block - best headers ?? [Re: indcontrols] #1972093
12/18/15 01:38 PM
12/18/15 01:38 PM
Oakdale CT
gdonovan Offline
gdonovan  Offline
Oakdale CT
Another vote for Doug's.
"I think its got a hemi"
Re: A body with small block - best headers ?? [Re: indcontrols] #1972123
12/18/15 02:27 PM
12/18/15 02:27 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
Went on autozones web site all they had were flowtecks didn't have dougs listed, got a link I can use?
Re: A body with small block - best headers ?? [Re: cudaman1969] #1972182
12/18/15 04:07 PM
12/18/15 04:07 PM
Locomotion Offline
Locomotion  Offline
I vote for TTI. Outside as well as inside coating options. The 1 5/8"-1 3/4" step could help HP and torque #'s a bit over the straight 1 5/8", especially when hopping the engine up. They work great on my race car too running mid-low 11's (with TTI X-pipe & Dynomaxmufflers). Easiest to install and best fitting chassis headers I ever had.
TTI Exhaust
Re: A body with small block - best headers ?? [Re: indcontrols] #1972258
12/18/15 06:40 PM
12/18/15 06:40 PM
Washington
madscientist Offline
Washington
Lose the power steering. Then order a set of 5204 Hookers.
Re: A body with small block - best headers ?? [Re: madscientist] #1972304
12/18/15 08:50 PM
12/18/15 08:50 PM
Renton Wa
topfueldart Offline
topfueldart  Offline
Renton Wa
Loved the TTI's I had on my car. Install from the bottom as directed, and they are a breeze, with great ground clearance.
11.48 @ 120 with a 1.80 60' 318, stock 1.88 heads, stock 904, Pump Gas, 13 lbs of boost.
9.94 @ 134, 318 on pump gas, 14 lbs w/ Eddies, transbrake 727, 3600 lbs, 3.54 gear and 28's.
