Notching the K-frame - do I need to brace it? #1969939
12/15/15 02:31 AM
12/15/15 02:31 AM
Tulsa, Ok
WadeMetzinger Offline OP
Tulsa, Ok
Built a new 340 for my dad's car and we've been running a stock pan but I have a Milodon pan on the shelf so I wanted to use it, extra 3qts of oil and better oil control.
We test fit it this weekend and I had to cut a pretty big notch in the K-frame for it to fit.
This is on a 1966 Barracuda /6 K-frame.
It looks like there is still plenty of metal to keep the K-frame stable but before I put the motor in I wanted to see what you guys thought.
I know they used to notch the k-frames pretty big when putting big blocks in 1967/1968 A-bodies back in the day.
Wade Metzinger 918-809-0987
71 Cuda 9.28@145 -1s, Pglide
68 Cuda 10.64@124 1.45 60's 318->390 eddys
Moparts discount code on WIX - moparts www.Filter1.com
Re: Notching the K-frame - do I need to brace it? [Re: WadeMetzinger] #1969945
12/15/15 02:40 AM
12/15/15 02:40 AM
Janesville, WI
SpareParts Offline
SpareParts  Offline
Janesville, WI
That's a baby notch!
Re: Notching the K-frame - do I need to brace it? [Re: SpareParts] #1969951
12/15/15 02:44 AM
12/15/15 02:44 AM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
The bigger question is what headers are you going to use. If they are the 1 7/8 headmen headers do LOTS of test fitting when using that pan. Ask me how I know.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Notching the K-frame - do I need to brace it? [Re: WadeMetzinger] #1969952
12/15/15 02:46 AM
12/15/15 02:46 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Weld in a vertical wall shaped to that and it'll
be fine
wave
Re: Notching the K-frame - do I need to brace it? [Re: WadeMetzinger] #1970011
12/15/15 08:26 AM
12/15/15 08:26 AM
Ft. Wayne, IN.
Q
QTR MILR Offline
QTR MILR  Offline
Q
Ft. Wayne, IN.
I would shape a plate and weld it in there. If nothing else it will keep debris out of it.
Scott
69 Satellite, 3650lb street car... Dunnuck Racing pump gas 440. Best of 10:60@127...
Re: Notching the K-frame - do I need to brace it? [Re: QTR MILR] #1970020
12/15/15 09:16 AM
12/15/15 09:16 AM
Buford, GA
I_bleed_MOPAR Offline
Buford, GA
iagree
The one I did I simply flipped the piece around and welded it back in (or rather, my Dad did the welding since I can't weld for shucks). up
Tim
'71 Charger 383/727
'17 Challenger SXT (Wifeys car wink )
Re: Notching the K-frame - do I need to brace it? [Re: WadeMetzinger] #1970021
12/15/15 09:23 AM
12/15/15 09:23 AM
MI, usa
dvw Offline
dvw  Offline
MI, usa
Not only would I plate it, but cut it bigger so that the pan can come off. You'll be glad you did later.
Doug
Re: Notching the K-frame - do I need to brace it? [Re: dvw] #1970629
12/16/15 01:47 AM
12/16/15 01:47 AM
fullmetaljacket Offline
Yes, weld in a shaped plate to close the wound and you will be okay.
