Lunati 10230703LK cam/lifter pkg.? #1969237
12/14/15 12:38 AM
12/14/15 12:38 AM
Long Island, NY
shakerjoe Offline OP
Long Island, NY
loooking for a cam for my 440... .030 over w/2355 six pack pistons, 906 heads 3 angle valve job stock size valves - 9.79 compression (thinking of bigger gasket to bring down to 9.5), alum intake w/stock rebuilt 6 pack carbs, stock HP exhaust manifolds, auto w/TF2 trans kit rebuilt to hemi specs, stock 11" hemi converter(FSM says 2400-2800 stall), 2.5" tti exhaust w/dynomax ultraflows, 3.55 8 3/4, 15x7 rally's w/245 60/15 BFG's - TIA
Advertised Duration (Int/Exh): 268/276
Duration @ .050 (Int/Exh): 226/234
Gross Valve Lift (Int/Exh): .494/.513
LSA/ICL: 110/106
Valve Lash (Int/Exh): Hyd/Hyd
RPM Range: 1800-6200
Includes: Cam & Lifters (#71977PR-16)
Re: Lunati 10230703LK cam/lifter pkg.? [Re: shakerjoe] #1969357
12/14/15 09:40 AM
12/14/15 09:40 AM
Norrland, Sweden
Swedcharger67 Offline
Norrland, Sweden
I have the kit in my 512, 12.4:1 compression engine. Since I want the power brakes to work in town I couldn't go any hotter cam. This cam is right at the minimum vacuum limit at idle.
Here is the sound from my sequentially injected engine with the 703 cam:
https://www.youtube.com/watch?v=wPup8rZdRM8
Martin, 67 Charger, 512 cui, E85, MegaSquirt MS3X sequential ignition & injection
Re: Lunati 10230703LK cam/lifter pkg.? [Re: shakerjoe] #1969481
12/14/15 03:29 PM
12/14/15 03:29 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
Another good option for that combo is the Crower 271HDP
Re: Lunati 10230703LK cam/lifter pkg.? [Re: Swedcharger67] #1969623
12/14/15 06:43 PM
12/14/15 06:43 PM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
Huh? Sure you're talking about the same cam? This cam is only 226/234 duration. It's very tame and will work good for the OP. I ran one in a smogger 440 and it wasn't even anywhere close to being a problem with power brakes.
Re: Lunati 10230703LK cam/lifter pkg.? [Re: DaytonaTurbo] #1969705
12/14/15 08:58 PM
12/14/15 08:58 PM
Long Island, NY
Long Island, NY
after speaking with Mike at Lunati a few times today, I ordered this setup with their double springs - said it would be perfect for my combo - fast 68 - my old cam is a Crower 283HDP but I had more converter in the car - 10" 3500 with 915 heads - thanks all
Re: Lunati 10230703LK cam/lifter pkg.? [Re: DaytonaTurbo] #1970024
12/15/15 09:49 AM
12/15/15 09:49 AM
Norrland, Sweden
Norrland, Sweden
I don't know the case with your engine but I asked Lunati to recommend a cam that would give me enough vacuum for my power brakes...and they were spot on with the 703...
Here in the upper right corner the manifold vacuum is measured and it's approx 45 kPa = 12 in Hg at a slightly elevated idle. This is just at the bare minimum vacuum for my power brakes.
https://www.youtube.com/watch?v=gBkS_PWq1YU
Re: Lunati 10230703LK cam/lifter pkg.? [Re: Swedcharger67] #1970131
12/15/15 01:30 PM
12/15/15 01:30 PM
Manitoba, Canada
Manitoba, Canada
Do you have to run race gas? I'm amazed a 12.4:1 512 is able to even run that cam. That thing should idle like a stock 440 with that tame of a cam in there. Does it want to pull past 5000rpm or is it about done?
