Filled exhaust crossover. #1967254
12/10/15 06:49 PM
12/10/15 06:49 PM
Texas
ChevyTS Offline OP
ChevyTS  Offline OP
Texas
I thought some may find this interesting.
T & K Performance
Re: Filled exhaust crossover. [Re: ChevyTS] #1967256
12/10/15 06:50 PM
12/10/15 06:50 PM
Texas
ChevyTS Offline OP
ChevyTS  Offline OP
Texas
Two more!
T & K Performance
Re: Filled exhaust crossover. [Re: ChevyTS] #1967266
12/10/15 07:03 PM
12/10/15 07:03 PM
MR_P_BODY Offline
MR_P_BODY  Offline
What did you fill it with?
wave
Re: Filled exhaust crossover. [Re: MR_P_BODY] #1967344
12/10/15 09:12 PM
12/10/15 09:12 PM
Eagle, Idaho
Neil Offline
The Doctor is in.
Neil  Offline
The Doctor is in.
Eagle, Idaho
My brother has done that to several sets of small block Oldsmobile heads. Zinc something or other is what they call it???
Re: Filled exhaust crossover. [Re: ChevyTS] #1967354
12/10/15 09:33 PM
12/10/15 09:33 PM
pennsylvania
poboyengineering Offline
pennsylvania
I've seen guys melt old pistons down to fill the crossover.
It may be ugly, but it sure is slow.
Girls comb their hair in rear view mirrors and the boys try to look so hard....
Re: Filled exhaust crossover. [Re: ChevyTS] #1967373
12/10/15 10:10 PM
12/10/15 10:10 PM
Texas
ChevyTS Offline OP
ChevyTS  Offline OP
Texas
I spared no expense! I used a hypereutectic aluminum alloy. An old piston wink
T & K Performance
Re: Filled exhaust crossover. [Re: ChevyTS] #1967409
12/10/15 11:09 PM
12/10/15 11:09 PM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
Looks good
Re: Filled exhaust crossover. [Re: FastmOp] #1967413
12/10/15 11:12 PM
12/10/15 11:12 PM
Texas
ChevyTS Offline OP
ChevyTS  Offline OP
Texas
Originally Posted By FastmOp
Looks good
Thank you.
T & K Performance
Re: Filled exhaust crossover. [Re: ChevyTS] #1967417
12/10/15 11:17 PM
12/10/15 11:17 PM
Washington
madscientist Offline
Washington
If you did it with the head at ambient, it will probably shrink and just clink around in there.
I gave up filling those along time ago. Found some flow on the bench but never found it on the dyno.
Re: Filled exhaust crossover. [Re: madscientist] #1967420
12/10/15 11:20 PM
12/10/15 11:20 PM
Maryland
twayne24365 Offline
twayne24365  Offline
Maryland
That's good to hear, I didn't block mine
Re: Filled exhaust crossover. [Re: twayne24365] #1967452
12/11/15 12:05 AM
12/11/15 12:05 AM
I use the Fel Pro valley pans with the heat cross over blocked off thumbsMost of the after market race intakes have no provisons in them so using the valley pan is doubling up on that. I've treid filling them with stainless steel wool and other things like that, none of it lasted shruggy
Re: Filled exhaust crossover. [Re: Cab_Burge] #1967460
12/11/15 12:20 AM
12/11/15 12:20 AM
Ambridge, Pa.
rickraw Online content
rickraw  Online Content
Ambridge, Pa.
I used a router with a flat carbide cutter, recessed the opening & epoxied a aluminum plate in the recess.Worked perfectly.
Re: Filled exhaust crossover. [Re: ChevyTS] #1967513
12/11/15 01:53 AM
12/11/15 01:53 AM
Texas
ChevyTS Offline OP
ChevyTS  Offline OP
Texas
I heated the cylinder head up before I filled the crossover. This was actually a practice run for job that I am working on. I am building a 1969 455 Olds engine with a set of C castings. The Olds heads have huge exhaust crossover passages. Filling then helps quite a bit.
T & K Performance
Re: Filled exhaust crossover. [Re: ChevyTS] #1967566
12/11/15 03:09 AM
12/11/15 03:09 AM
Washington
Washington
Then you have a much better chance of it staying in there.
Never tested it on an Olds so hope you post the results.
