Filled exhaust crossover.
#1967254
12/10/15 06:49 PM
12/10/15 06:49 PM
Posts: 576 Texas
ChevyTS
Texas
I thought some may find this interesting.
T & K Performance
Re: Filled exhaust crossover.
[Re: ChevyTS]
#1967256
12/10/15 06:50 PM
12/10/15 06:50 PM
Posts: 576 Texas
ChevyTS
Texas
Two more!
T & K Performance
[Re: ChevyTS]
#1967354
12/10/15 09:33 PM
12/10/15 09:33 PM
Posts: 685 pennsylvania
poboyengineering
pennsylvania
I've seen guys melt old pistons down to fill the crossover.
It may be ugly, but it sure is slow.
Girls comb their hair in rear view mirrors and the boys try to look so hard....
[Re: ChevyTS]
#1967417
12/10/15 11:17 PM
12/10/15 11:17 PM
Posts: 4,457 Washington
madscientist
Washington
If you did it with the head at ambient, it will probably shrink and just clink around in there.
I gave up filling those along time ago. Found some flow on the bench but never found it on the dyno.
[Re: madscientist]
#1967420
12/10/15 11:20 PM
12/10/15 11:20 PM
Posts: 181 Maryland
twayne24365
Maryland
I gave up filling those along time ago. Found some flow on the bench but never found it on the dyno. That's good to hear, I didn't block mine
[Re: ChevyTS]
#1967513
12/11/15 01:53 AM
12/11/15 01:53 AM
Posts: 576 Texas
ChevyTS
Texas
I heated the cylinder head up before I filled the crossover. This was actually a practice run for job that I am working on. I am building a 1969 455 Olds engine with a set of C castings. The Olds heads have huge exhaust crossover passages. Filling then helps quite a bit.
T & K Performance
[Re: ChevyTS]
#1967566
12/11/15 03:09 AM
12/11/15 03:09 AM
madscientist
Washington
I heated the cylinder head up before I filled the crossover. This was actually a practice run for job that I am working on. I am building a 1969 455 Olds engine with a set of C castings. The Olds heads have huge exhaust crossover passages. Filling then helps quite a bit. Then you have a much better chance of it staying in there. Never tested it on an Olds so hope you post the results.
