Re: Who's the Door Window expert here?
[Re: clonestocker]
#1966101
12/09/15 02:30 AM
12/09/15 02:30 AM
htpd437
htpd437
only way to get help is to post the questions.......
[Re: ]
#1966448
12/09/15 06:01 PM
12/09/15 06:01 PM
Posts: 2,155 Tucson, Arizona
clonestocker
Tucson, Arizona
only way to get help is to post the questions....... You mustn't be the guy I'm looking for. ![smile smile](/ubbthreads/images/graemlins/custom/smile.gif)
[img] [/img]
[Re: flypaper]
#1966597
12/09/15 10:05 PM
12/09/15 10:05 PM
Posts: 2,592 None
71rm23
None
What year/model car are we refering to?
This feels like 20 questions.. X2
[Re: minivan]
#1966706
12/10/15 12:17 AM
12/10/15 12:17 AM
clonestocker
Tucson, Arizona
R U asking about "what door glass fits what"?
Or some help with assembly?
Here's the deal. I'm working on 1972 Duster which has specific window mounting hardware. Well you get the kit that is year specific and only part of the pieces are right and where are the instructions? NOT Has anybody tried to find an exploded view of the windows and how to mount them? NOT Sure glad the window was broken and the other one wasn't taken apart. At least I have a visual. I've also put this out there before and received little or no response. That's why the first post was so blunt. Any of you members have what I'm looking for? thx matt
[img] [/img]
[Re: flypaper]
#1966734
12/10/15 12:45 AM
12/10/15 12:45 AM
clonestocker
Tucson, Arizona
I have the 72 Chassis and Body manuals and it shows nothing. It's called a Valiant ventless door glass. Show nothing.
[img] [/img]
[Re: Alaskan_TA]
#1966981
12/10/15 12:18 PM
12/10/15 12:18 PM
clonestocker
Tucson, Arizona
I have a similar illustration but lets see something with an exploded view. How the mounts go into the glass. Where the paper gaskets go, etc. What's involved for replacing the track rollers. Where the pieces in the kit go. Thanks for the help guys.
[img] [/img]
[Re: clonestocker]
#1967164
12/10/15 04:16 PM
12/10/15 04:16 PM
Posts: 9,066 Eugene, Oregon
minivan
Eugene, Oregon
It can be a little overwhelming..
As an apprentice in 76, my first job was a Lincoln door glass with the automatic vent window.. The new replacement window had 9 holes in it, and I had a whole bunch of roller gizmos sitting in the bottom of the door with a million bits of broken glass ( tempered glass).. I almost quit that day....LOL
You said the other side was together? You should be able to use it as a guide..
What you need to do is one piece at a time.. If you set the channels in your doors they can only line up a certain way and work.. Does the piece that fits the bottom of the glass ( that the regulator rollers fit into) do so with a thick piece of rubbery looking gasket material? Again look at the other side for placement on the glass.. If you are not comfortable attaching it to the glass, take it to an Auto Glass shop with your measurements and let them do it..
[Re: clonestocker]
#1976967
12/27/15 03:39 AM
12/27/15 03:39 AM
Posts: 18,632 jersey shore
flypaper
I hate Texas
I hate Texas
jersey shore
I have a similar illustration but lets see something with an exploded view. How the mounts go into the glass. Where the paper gaskets go, etc. What's involved for replacing the track rollers. Where the pieces in the kit go. Thanks for the help guys. you need to disassemble your door and lay out what you have in the kit in front of you and see what you have that will fit. some of these kits do not have all the parts or they have plastic parts to replace metal ones. do a door at a time so you can see how it goes together if need be. for the rollers the ones that i have replaced you have to grind off the old ones from the backside and then pry them off the arm. then install the new ones in the same hole then you swedge the ends over good with a hammer. its not that hard to do.
