OEM 440 Cast piston weight #196696
01/18/09 12:06 AM
01/18/09 12:06 AM
Madison Wi
NTOLERANCE Offline OP
Madison Wi
Anyone know what a stock 440 piston weighs? Searched on the net and couldnt find the info.
Re: OEM 440 Cast piston weight [Re: NTOLERANCE] #196697
01/18/09 12:26 AM
01/18/09 12:26 AM
801.5 grams + or - 2 grams(std thru .040" oversize) EDIT from a '77 shop manual
Re: OEM 440 Cast piston weight [Re: RapidRobert] #196698
01/18/09 01:03 AM
01/18/09 01:03 AM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
My factory service manual says 857g for a 74 440 piston.
Re: OEM 440 Cast piston weight [Re: DaytonaTurbo] #196699
01/18/09 01:19 AM
01/18/09 01:19 AM
Madison Wi
Madison Wi
Would it matter if the engine had a cast or forged crank?
Re: OEM 440 Cast piston weight [Re: RapidRobert] #196700
01/18/09 08:27 AM
01/18/09 08:27 AM
Andrews,In. U.S.of A.
67_Satellite Offline
+ or - 2 grams
I don't doubt your honesty,but I would bet the real world weight was much more than + or - 2 grams. What is 2 grams out of 800, like .250% Yeah,sure, the factory held them that close all day long back then. Don't forget to add a ton for the overengineered pin.
Re: OEM 440 Cast piston weight [Re: NTOLERANCE] #196701
01/18/09 08:59 AM
01/18/09 08:59 AM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
1967 440 measured at 854g
Re: OEM 440 Cast piston weight [Re: 67_Satellite] #196702
01/18/09 11:28 AM
01/18/09 11:28 AM
+ or - 2 grams
Hey I appreciate the vote of confidence in my honesty. You're the only one . Actually my honesty varies from day to day depending on who I am in contact with(& who I have to tolerate ) and what kind of mood I am in. The + or - 2 grams was the info I copied out of my shop manual & copying was a skill that I became very adept at way back when I was in school another testimony to my "honesty"
Re: OEM 440 Cast piston weight [Re: NTOLERANCE] #196703
01/18/09 02:46 PM
01/18/09 02:46 PM
Abilene, Texas
fastmark Offline
fastmark  Offline
Abilene, Texas
I just boxed up my original 70 440-6 pistons and I had one weighed and marked at 867 grams.
