Re: OEM 440 Cast piston weight
[Re: NTOLERANCE]
#196697
01/18/09 12:26 AM
01/18/09 12:26 AM
RapidRobert
801.5 grams + or - 2 grams(std thru .040" oversize) EDIT from a '77 shop manual
[Re: DaytonaTurbo]
#196699
01/18/09 01:19 AM
01/18/09 01:19 AM
Posts: 4,384 Madison Wi
NTOLERANCE
Madison Wi
Would it matter if the engine had a cast or forged crank?
[Re: RapidRobert]
#196700
01/18/09 08:27 AM
01/18/09 08:27 AM
Posts: 1,020 Andrews,In. U.S.of A.
67_Satellite
+ or - 2 grams
I don't doubt your honesty,but I would bet the real world weight was much more than + or - 2 grams. What is 2 grams out of 800, like .250% Yeah,sure, the factory held them that close all day long back then. Don't forget to add a ton for the overengineered pin.
