95 grand cherokee front lower control arms replace #1965637
12/08/15 04:07 PM
12/08/15 04:07 PM
Wisconsin USA
themoparmanjc Offline OP
Wisconsin USA
I recently purchased a 95 jeep grand cherokee. I ordered new control arms for it because they were only 30 each with new bushings already installed. I went to change them yesterday and i couldn't get the front cam bolts out. I got the lock nuts off and tried turning the bolts out and they would only turn a short distance then "spring" back to their original position. I had it jacked up with the suspension hanging freely and i tried putting jack stands under the front axle. Either way it made no difference. I even used a 4 foot breaker bar and it kept wanting to go back to where it was. I screwed the nut partially on the bolt and hit it with a hammer but no luck. Any ideas?
Don’t Buy From Famous Bob AKA Bob McCarty in Oklahoma. He is a Crook!
Re: 95 grand cherokee front lower control arms replace [Re: themoparmanjc] #1965705
12/08/15 05:17 PM
12/08/15 05:17 PM
enfield, CT
ViperDave Offline
ViperDave  Offline
enfield, CT
the bolts are seized onto the inner bushing sleeve. I would cut the bolts off and replace
Common problem, I believe the moog part number is MOOG K100047 for new bolt/nut
You could heat the crap out of it, melt the bushing and maybe the sleeve will turn...
67 Dart GT Vert 273/904
72 Town & Country 440/727
90 D350 reg cab dually cummins
15 Scat Pack Challenger
Re: 95 grand cherokee front lower control arms replace [Re: themoparmanjc] #1966103
12/09/15 02:35 AM
12/09/15 02:35 AM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
Cut the bolt on both sides of the bushing, remove all the pieces and put a new bolt in with the control arms. I'd give the new bolts a coating of antiseeze as you install them. Gene
Re: 95 grand cherokee front lower control arms replace [Re: poorboy] #1966104
12/09/15 02:35 AM
12/09/15 02:35 AM
Wisconsin USA
Wisconsin USA
Ok. Thanks guys
