Caravan inner tie rods #1965364
12/08/15 02:11 AM
12/08/15 02:11 AM
Hamilton, Ontario Canada
Magnum Offline OP
Magnum  Offline OP
I need to change the inners on my wife's 99 Caravan.
Is a special tool required or can they be unscrewed with a regular wrench?
Re: Caravan inner tie rods [Re: Magnum] #1965368
12/08/15 02:15 AM
12/08/15 02:15 AM
Benton, IL.
DaveRS23 Online rolleyes
Special needs idiot
DaveRS23  Online Rolleyes
Special needs idiot
Benton, IL.
Probably gonna need the tool. They are a pain to get to and the clamps on the boots are a pain, too.
O'Reilly's, among others have the tool for rent.
Master, again and still
Re: Caravan inner tie rods [Re: DaveRS23] #1965454
12/08/15 10:48 AM
12/08/15 10:48 AM
moparx Offline
moparx  Offline
i made a couple of tools years ago when they were stupid money. i took a thick, open end wrench that fit the tie rod well, and welded on a screwed up impact socket that i had clearanced for room on a bridgeport, saving the female 1/2" drive pocket. just think of a really beefy crows foot wrench. it took longer than it sounds because it took multiple fits with grinding/milling interference points before it worked as was intended. i still have those tools and use them occasionally. with today's inexpensive imported tools, you would be time & money ahead to just purchase or rent one. especially if it will only be a one time use deal. as was said, lots of chain stores will help you out with the tool if you buy the part from them. i never throw away broken tools [unless they are lifetime warrantee items]. i never know what i might want to make into a one time use/specialty tool or socket. and i have a BUNCH of those made over a 50 year span of playing with cars.
beer
Re: Caravan inner tie rods [Re: Magnum] #1965521
12/08/15 01:01 PM
12/08/15 01:01 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
A large crows foot will get them off.I have like 3 or 4 that I used at work for just that as different cars have different sizes.Some have a roll pin some have a flat that gets punched down to help lock them.I use loctight also.Just get the new one and go buy a crows foot or rent the tool from most big stores.Turn the wheel all the way out to the side you change makes it pretty easy.Rocky
Chrysler Firepower
Re: Caravan inner tie rods [Re: therocks] #1966316
12/09/15 02:47 PM
12/09/15 02:47 PM
dogdays Offline
dogdays  Offline
I made mine with a cheap socket, a piece of pipe and half of a 1/2" universal joint. After I was all done I could nearly have just bought the doggone tool.
One thing I found out the hard way, you have to keep the rack from twisting with a wrench or something or else the rack will rotate and break teeth on the pinion.
I really felt stupid when I did that.
R.
Re: Caravan inner tie rods [Re: Magnum] #1966497
12/09/15 08:03 PM
12/09/15 08:03 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
Ive done hundreds and never twisted a rack or broke anything.Did them all the time at the shop.Like I said some have a pin and some are crimped where it meets the rack.Still never had a problem without removing the crimp and on soem the pin.Rocky
Chrysler Firepower
Re: Caravan inner tie rods [Re: therocks] #1967034
12/10/15 01:36 PM
12/10/15 01:36 PM
dogdays Offline
dogdays  Offline
Rocky, maybe you were lucky. Maybe I was unlucky. But I bet you never disassembled a rack and pinion after you finished removing/replacing the inner tie rods. The R&P drove fine after that. About 20K miles later I started a total rebuild of the car and decided to change seals and bushings in the steering gear. It wasn't until I pulled the pinion that I saw the damage to the pinion. About half of each tooth on the pinion was gone, and it wasn't a factory defect.
As it was on a limited production car and not shared with any other car, it was costly to replace, and so I remember it.
R.
Re: Caravan inner tie rods [Re: Magnum] #1967253
12/10/15 06:48 PM
12/10/15 06:48 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
You still had to be unlucky or did something wrong.Ive done them since the 80s and never had a problem and these cars etc went years.It was common at the shop to do them.I guess doing them for over 30 years gave me an edge.Rocky
Chrysler Firepower
Re: Caravan inner tie rods [Re: Magnum] #1968185
12/12/15 02:26 AM
12/12/15 02:26 AM
Magnum Offline OP
Magnum  Offline OP
My inners had no flats. I bought a tool that ressembles a heavy duty muffler clamp with a 3/8s hole in it.
Re: Caravan inner tie rods [Re: Magnum] #1968348
12/12/15 01:53 PM
12/12/15 01:53 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
The most common tool looks like a long socket and has different ends that slip in for different cars.I just used crows feet as they were cheaper at the time and worked for other things.I still have a bunch in my tool box.Just use a good long extension and 1/2 inch ratchet and they are out.Rocky
Chrysler Firepower
Re: Caravan inner tie rods [Re: Magnum] #1968618
12/12/15 10:26 PM
12/12/15 10:26 PM
Magnum Offline OP
Magnum  Offline OP
Yes rocks. I also read it elsewhere thats the tool to have. Borrowed one and sadly found a round inner joint. The Moog replacements had flats😀
Re: Caravan inner tie rods [Re: Magnum] #1968620
12/12/15 10:26 PM
12/12/15 10:26 PM
Magnum Offline OP
Magnum  Offline OP
Re: Caravan inner tie rods [Re: Magnum] #1968773
12/13/15 02:44 AM
12/13/15 02:44 AM
Ohio
Todd Offline
Todd  Offline
Ohio
On the round ones, I cut the tie rod off at the joint and hammer a 12 point socket over it. Fords contours were bad for that.
