Caravan inner tie rods
#1965364
12/08/15 02:11 AM
12/08/15 02:11 AM
Posts: 5,791 Hamilton, Ontario Canada
Magnum
I need to change the inners on my wife's 99 Caravan.
Is a special tool required or can they be unscrewed with a regular wrench?
Re: Caravan inner tie rods
[Re: Magnum]
#1965368
12/08/15 02:15 AM
12/08/15 02:15 AM
Posts: 12,158 Benton, IL.
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
Probably gonna need the tool. They are a pain to get to and the clamps on the boots are a pain, too.
O'Reilly's, among others have the tool for rent.
Master, again and still
[Re: Magnum]
#1965521
12/08/15 01:01 PM
12/08/15 01:01 PM
Posts: 21,076 Niles , Ohio
therocks
Niles , Ohio
A large crows foot will get them off.I have like 3 or 4 that I used at work for just that as different cars have different sizes.Some have a roll pin some have a flat that gets punched down to help lock them.I use loctight also.Just get the new one and go buy a crows foot or rent the tool from most big stores.Turn the wheel all the way out to the side you change makes it pretty easy.Rocky
Chrysler Firepower
[Re: Magnum]
#1966497
12/09/15 08:03 PM
12/09/15 08:03 PM
therocks
Niles , Ohio
Ive done hundreds and never twisted a rack or broke anything.Did them all the time at the shop.Like I said some have a pin and some are crimped where it meets the rack.Still never had a problem without removing the crimp and on soem the pin.Rocky
Chrysler Firepower
[Re: Magnum]
#1967253
12/10/15 06:48 PM
12/10/15 06:48 PM
therocks
Niles , Ohio
You still had to be unlucky or did something wrong.Ive done them since the 80s and never had a problem and these cars etc went years.It was common at the shop to do them.I guess doing them for over 30 years gave me an edge.Rocky
Chrysler Firepower
[Re: Magnum]
#1968185
12/12/15 02:26 AM
12/12/15 02:26 AM
Magnum
My inners had no flats. I bought a tool that ressembles a heavy duty muffler clamp with a 3/8s hole in it.
[Re: Magnum]
#1968348
12/12/15 01:53 PM
12/12/15 01:53 PM
therocks
Niles , Ohio
The most common tool looks like a long socket and has different ends that slip in for different cars.I just used crows feet as they were cheaper at the time and worked for other things.I still have a bunch in my tool box.Just use a good long extension and 1/2 inch ratchet and they are out.Rocky
Chrysler Firepower
[Re: Magnum]
#1968618
12/12/15 10:26 PM
12/12/15 10:26 PM
Magnum
Yes rocks. I also read it elsewhere thats the tool to have. Borrowed one and sadly found a round inner joint. The Moog replacements had flats😀
[Re: Magnum]
#1968620
12/12/15 10:26 PM
12/12/15 10:26 PM
Magnum
