5.7 stock crank question #1961993
12/02/15 08:43 PM
12/02/15 08:43 PM
fredericksburg,va
cudaman1969 Offline OP
fredericksburg,va
Ok, I hear the cranks are weak but who has broken a 5.7 crank and how much power or rpm did it take?
Re: 5.7 stock crank question [Re: cudaman1969] #1962047
12/02/15 10:01 PM
12/02/15 10:01 PM
South Dakota
kilo1 Offline
kilo1  Offline
South Dakota
Not many broken cranks that I have seen , on engines with about 600 HP with no issues.
USMC 1982-1988
GM Parts 1988 -2006
US Army 2006-2015
Re: 5.7 stock crank question [Re: cudaman1969] #1962103
12/02/15 11:27 PM
12/02/15 11:27 PM
Oakland, MI
dizuster Offline
dizuster  Offline
Oakland, MI
I have two stock core motors, one has a broken crank. But I haven't taken it apart to diagnose. But it's just stock... Not 600hp
Re: 5.7 stock crank question [Re: dizuster] #1962105
12/02/15 11:31 PM
12/02/15 11:31 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
I have seen a lot of broken rods in 5.7s but never a broken crank.
Re: 5.7 stock crank question [Re: cudaman1969] #1962144
12/03/15 12:16 AM
12/03/15 12:16 AM
Stinnett, Tx
rumblebee4232 Offline
Stinnett, Tx
Never seen a broken crank just rods.. one I bought to use as a stroker had a rod journal that was wore down 1/4 inch(below the surface all the way around) that was still running when they pulled it because it was making noise..
Re: 5.7 stock crank question [Re: cudaman1969] #1962305
12/03/15 11:41 AM
12/03/15 11:41 AM
Houston Tx
Uhcoog1 Offline
Uhcoog1  Offline
Houston Tx
Lots of used forged takeout 6.1 cranks out there for cheap ($150). Not worth running the stock 5.7 crank if building the motor IMO
-'02 Dodge Viper Ex-World Challenge racecar
-'73 Duster, 6.1 based 392 hilborn hemi, tko600, full floater rear 9", Hellwig custom bars, viper brakes, built for road course
Re: 5.7 stock crank question [Re: Uhcoog1] #1962378
12/03/15 02:16 PM
12/03/15 02:16 PM
fredericksburg,va
fredericksburg,va
Been looking, I haven't found one that cheap, let me know if you know of one somewhere. Best I found was $450
Re: 5.7 stock crank question [Re: cudaman1969] #1962407
12/03/15 03:04 PM
12/03/15 03:04 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
I heAr the 6.1 crank drops in but how could the balance be right with bigger bores resulting in bigger pistons and rings? Or is it just close enough it don't make a difference?
Re: 5.7 stock crank question [Re: cudaman1969] #1962672
12/03/15 09:43 PM
12/03/15 09:43 PM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
I would balance with the 5.7 bore pistons used and whatever rods of choice. Also would use a 6.1,balancer at a bare minimum.
Mopar to the bone!!!
Re: 5.7 stock crank question [Re: cudaman1969] #1962675
12/03/15 09:48 PM
12/03/15 09:48 PM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
Also wanted to add that the 6.1 crank I pulled out of my core engine is NICE. All counterweights fully machined and dressed, no rough flashing anywhere. The Manley I replaced it with only had drilled rod journals as an advantage.
Re: 5.7 stock crank question [Re: cudaman1969] #1962852
12/04/15 01:43 AM
12/04/15 01:43 AM
Toronto
mshred Offline
mshred  Offline
Toronto
Isn't there the higher rpm oiling issue though with the stock cranks?
Re: 5.7 stock crank question [Re: cudaman1969] #1963307
12/04/15 07:17 PM
12/04/15 07:17 PM
Houston Tx
Uhcoog1 Offline
Uhcoog1  Offline
Houston Tx
Try LXforums. Or I have one out of a spun rod bearing motor, just no box for it ATM.
They are cross drilled. The drag pak guys turn em to 8200-8500 without issue with a 9 qt pan + 3 qt accusump. You will run a 6 qt swap pan dry around 7500 (ask Joe- he knows first-hand).
Re: 5.7 stock crank question [Re: Uhcoog1] #1963420
12/04/15 11:09 PM
12/04/15 11:09 PM
Belpre,Ohio
CHAPPER Offline
CHAPPER  Offline
Belpre,Ohio
I had a 10qt pan with belt drive Barnes oil system turning about 7200-7300 RPM and the stock crank......#3 rod quit oiling...DEVASTATING results. Molnar crank and no problems at 7800-8000 RPM. This has been hashed out for quite awhile. I, and many others, have concluded that there is a problem with the stock crank oiling. JMO...$.02...etc. Try one yourself and report back later.??
If you like drag racing, support your local track.
Re: 5.7 stock crank question [Re: cudaman1969] #1963437
12/04/15 11:36 PM
12/04/15 11:36 PM
USA
hudsonhornet7x Offline
USA
Would this be ALL stock cranks, 6.1 and 6.4 included?
Re: 5.7 stock crank question [Re: cudaman1969] #1963441
12/04/15 11:37 PM
12/04/15 11:37 PM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
I think the 6.1's have better prep than 5.7's.
Re: 5.7 stock crank question [Re: CHAPPER] #1963810
12/05/15 03:58 PM
12/05/15 03:58 PM
fredericksburg,va
fredericksburg,va
Are the 6.1-6.4 cranks drilled the same as 5.7? Are the steel factory cranks junk too?
Re: 5.7 stock crank question [Re: cudaman1969] #1963869
12/05/15 06:04 PM
12/05/15 06:04 PM
Ontario Canada
MattW Offline
MattW  Offline
Ontario Canada
No they 6.1 6.4 and I'm thinking 6.2 are not drill all the way through the mains.
I posted picture of 6.1 and 5.7 crank on here.
Re: 5.7 stock crank question [Re: cudaman1969] #1963895
12/05/15 06:49 PM
12/05/15 06:49 PM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
The 6.1 crank in my above pics was a high mileage, broken valve spring core engine. Only imperfection was #3 main had a light scratch that would easily polish out. You can see it in the pics. It ate something as I think #3 is what feeds the heads IIRC.
