Re: 5.7 stock crank question
[Re: cudaman1969]
#1962047
12/02/15 10:01 PM
12/02/15 10:01 PM
Posts: 491 South Dakota
kilo1
South Dakota
Not many broken cranks that I have seen , on engines with about 600 HP with no issues.
USMC 1982-1988 GM Parts 1988 -2006 US Army 2006-2015
[Re: dizuster]
#1962105
12/02/15 11:31 PM
12/02/15 11:31 PM
Posts: 12,422 Kalispell Mt.
HotRodDave
Kalispell Mt.
I have seen a lot of broken rods in 5.7s but never a broken crank.
[Re: cudaman1969]
#1962305
12/03/15 11:41 AM
12/03/15 11:41 AM
Posts: 723 Houston Tx
Uhcoog1
Houston Tx
Lots of used forged takeout 6.1 cranks out there for cheap ($150). Not worth running the stock 5.7 crank if building the motor IMO
-'02 Dodge Viper Ex-World Challenge racecar -'73 Duster, 6.1 based 392 hilborn hemi, tko600, full floater rear 9", Hellwig custom bars, viper brakes, built for road course
[Re: Uhcoog1]
#1962378
12/03/15 02:16 PM
12/03/15 02:16 PM
Posts: 8,325 fredericksburg,va
cudaman1969
fredericksburg,va
Lots of used forged takeout 6.1 cranks out there for cheap ($150). Not worth running the stock 5.7 crank if building the motor IMO Been looking, I haven't found one that cheap, let me know if you know of one somewhere. Best I found was $450
[Re: cudaman1969]
#1962407
12/03/15 03:04 PM
12/03/15 03:04 PM
HotRodDave
Kalispell Mt.
I heAr the 6.1 crank drops in but how could the balance be right with bigger bores resulting in bigger pistons and rings? Or is it just close enough it don't make a difference?
[Re: cudaman1969]
#1962672
12/03/15 09:43 PM
12/03/15 09:43 PM
Posts: 4,302 Nebraska
72Swinger
Nebraska
I would balance with the 5.7 bore pistons used and whatever rods of choice. Also would use a 6.1,balancer at a bare minimum.
Mopar to the bone!!!
[Re: cudaman1969]
#1962675
12/03/15 09:48 PM
12/03/15 09:48 PM
72Swinger
Nebraska
Also wanted to add that the 6.1 crank I pulled out of my core engine is NICE. All counterweights fully machined and dressed, no rough flashing anywhere. The Manley I replaced it with only had drilled rod journals as an advantage.
[Re: cudaman1969]
#1963307
12/04/15 07:17 PM
12/04/15 07:17 PM
Uhcoog1
Houston Tx
Lots of used forged takeout 6.1 cranks out there for cheap ($150). Not worth running the stock 5.7 crank if building the motor IMO Been looking, I haven't found one that cheap, let me know if you know of one somewhere. Best I found was $450 Try LXforums. Or I have one out of a spun rod bearing motor, just no box for it ATM. Isn't there the higher rpm oiling issue though with the stock cranks? They are cross drilled. The drag pak guys turn em to 8200-8500 without issue with a 9 qt pan + 3 qt accusump. You will run a 6 qt swap pan dry around 7500 (ask Joe- he knows first-hand).
[Re: Uhcoog1]
#1963420
12/04/15 11:09 PM
12/04/15 11:09 PM
Posts: 3,410 Belpre,Ohio
CHAPPER
Belpre,Ohio
Lots of used forged takeout 6.1 cranks out there for cheap ($150). Not worth running the stock 5.7 crank if building the motor IMO Been looking, I haven't found one that cheap, let me know if you know of one somewhere. Best I found was $450 Try LXforums. Or I have one out of a spun rod bearing motor, just no box for it ATM. Isn't there the higher rpm oiling issue though with the stock cranks? They are cross drilled. The drag pak guys turn em to 8200-8500 without issue with a 9 qt pan + 3 qt accusump. You will run a 6 qt swap pan dry around 7500 (ask Joe- he knows first-hand). I had a 10qt pan with belt drive Barnes oil system turning about 7200-7300 RPM and the stock crank......#3 rod quit oiling...DEVASTATING results. Molnar crank and no problems at 7800-8000 RPM. This has been hashed out for quite awhile. I, and many others, have concluded that there is a problem with the stock crank oiling. JMO...$.02...etc. Try one yourself and report back later.??
If you like drag racing, support your local track.
[Re: CHAPPER]
#1963810
12/05/15 03:58 PM
12/05/15 03:58 PM
cudaman1969
fredericksburg,va
Lots of used forged takeout 6.1 cranks out there for cheap ($150). Not worth running the stock 5.7 crank if building the motor IMO Been looking, I haven't found one that cheap, let me know if you know of one somewhere. Best I found was $450 Try LXforums. Or I have one out of a spun rod bearing motor, just no box for it ATM. Isn't there the higher rpm oiling issue though with the stock cranks? They are cross drilled. The drag pak guys turn em to 8200-8500 without issue with a 9 qt pan + 3 qt accusump. You will run a 6 qt swap pan dry around 7500 (ask Joe- he knows first-hand). I had a 10qt pan with belt drive Barnes oil system turning about 7200-7300 RPM and the stock crank......#3 rod quit oiling...DEVASTATING results. Molnar crank and no problems at 7800-8000 RPM. This has been hashed out for quite awhile. I, and many others, have concluded that there is a problem with the stock crank oiling. JMO...$.02...etc. Try one yourself and report back later.?? Are the 6.1-6.4 cranks drilled the same as 5.7? Are the steel factory cranks junk too?
[Re: cudaman1969]
#1963895
12/05/15 06:49 PM
12/05/15 06:49 PM
72Swinger
Nebraska
The 6.1 crank in my above pics was a high mileage, broken valve spring core engine. Only imperfection was #3 main had a light scratch that would easily polish out. You can see it in the pics. It ate something as I think #3 is what feeds the heads IIRC.
