Re: Tranny Fluid Which one to use? [Re: DavidDean] #196194
01/18/09 01:04 AM
01/18/09 01:04 AM
MR_P_BODY Offline
MR_P_BODY  Offline
I use mobil1 syn with Lucas additive, runs about 20*-30*coooler than conventional ATF.Clutches and bands usually look good. 408 SB 6.09 @110 @2000DA
I have no idea what mine looks like inside... its
been 4 years since I opened it up... its still working
fine
Re: Tranny Fluid Which one to use? [Re: MR_P_BODY] #196195
01/18/09 01:37 AM
01/18/09 01:37 AM
Roseau, MN
1976 Aspen Offline
1976 Aspen  Offline
Roseau, MN
John @ CRT recommends Pennzoil Dexron
Re: Tranny Fluid Which one to use? [Re: 1976 Aspen] #196196
01/18/09 10:56 AM
01/18/09 10:56 AM
Central New York
slippery440 Offline
Crybaby440
slippery440  Offline
Crybaby440
Central New York
What do you guys use with alum.drums? Sorry for the hyjack of the post. Just didn,t want to start anouther post with the same question.
If the MODS did their job I would not be hitting the notify MOD button. LOL
Re: Tranny Fluid Which one to use? [Re: dave571] #196197
03/19/09 08:34 PM
03/19/09 08:34 PM
Seattle, WA
3
375inStroke Offline
Special needs person
375inStroke  Offline
3
Seattle, WA
...dexron 3 more than exceeds any specs your mopar trans would have had initially.
Newer fluids (like atf +4) are simply better fluids, with better heat properties etc..
I'm skeptical of this. We all know how they tell us the new oil specs exceed the requirements of the old oils, and that there isn't enough ZDDP in there for our flat tappet cams. What aren't they telling us about the new ATFs?
Re: Tranny Fluid Which one to use? [Re: 375inStroke] #196198
03/19/09 08:46 PM
03/19/09 08:46 PM
Kokomo, IN
540dust Offline
540dust  Offline
Kokomo, IN
Type F, currently Castrol.
Re: Tranny Fluid Which one to use? [Re: 540dust] #196199
03/19/09 08:53 PM
03/19/09 08:53 PM
Akron, Ohio
ProSport Offline
ProSport  Offline
Akron, Ohio
My tranny guy has me buy regular DexMerc from Advance or anywhere else.
Re: Tranny Fluid Which one to use? [Re: 375inStroke] #196200
03/20/09 01:11 AM
03/20/09 01:11 AM
Carstairs, Alberta, Canada
dave571 Offline
dave571  Offline
Modern ATF's have to be better, because the operating demands of newer applications are much higher. 6 speed autos in cars, Bigger trucks than ever, more power, and of course the fact that no one in the world seems to want to cruise at less than 10 over the speed limit regardless of how big a load they are hauling
Re: Tranny Fluid Which one to use? [Re: dave571] #196201
03/20/09 05:59 AM
03/20/09 05:59 AM
Russiaville, IN
mopar376d Offline
mopar376d  Offline
Russiaville, IN
Type F
Re: Tranny Fluid Which one to use? [Re: mopar376d] #196202
03/20/09 07:32 AM
03/20/09 07:32 AM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
Easy decision for a cave man or bear,Dextron-3,don't have any trans or converter problems.We have many of our trans/converters with 1000+ runs and only adjust the bands every few years.My 65 has 1750 runs on the trans and only had 1 high gear clutch pack replaced and a 1 reseal.Go figure? Of course what do I know,I don't even know how to set up suspensions,but I must be lucky.
Re: Tranny Fluid Which one to use? [Re: mopar376d] #196203
03/20/09 07:33 AM
03/20/09 07:33 AM
Type F
Re: Tranny Fluid Which one to use? [Re: MR_P_BODY] #196204
03/20/09 08:33 AM
03/20/09 08:33 AM
S.E. Michigan
cl440 Offline
cl440  Offline
S.E. Michigan
Auto store.. type F here
Same here.
Re: Tranny Fluid Which one to use? [Re: cl440] #196205
03/20/09 06:10 PM
03/20/09 06:10 PM
central ohio
N
nss guy Offline
nss guy  Offline
N
central ohio
A&A trans-- cheapest type F fluid, change every 30-50 runs. Trans clutches look new
Re: Tranny Fluid Which one to use? [Re: nss guy] #196206
03/20/09 09:07 PM
03/20/09 09:07 PM
SW Ohio
cgall Offline
cgall  Offline
SW Ohio
All it is, is hydraulic fluid to push spools and vanes. Coastal type F here, $5.99 per gal at Autozone.
Re: Tranny Fluid Which one to use? [Re: cgall] #196207
03/20/09 09:29 PM
03/20/09 09:29 PM
nc
E
emarine01 Offline
emarine01  Offline
E
nc
Been using type F for three years , change once a season to check bands , fluid allways came out looking new
Re: Tranny Fluid Which one to use? [Re: blownzoom440] #196208
03/20/09 09:31 PM
03/20/09 09:31 PM
On the run…
BloFish Offline
BloFish  Offline
On the run…
Type F here as well
It really doesn't matter whether you win or lose…
as long as you look good doing it!
‘65 A100
‘69 ‘Cuda
‘73 Vega GT
‘06 Mega Cab
‘14 Mercedes SLK
Re: Tranny Fluid Which one to use? [Re: BloFish] #196209
03/20/09 11:09 PM
03/20/09 11:09 PM
Bridgeport, WV
Michael Offline
Michael  Offline
Bridgeport, WV
Dexron 111
Re: Tranny Fluid Which one to use? [Re: Michael] #196210
03/20/09 11:26 PM
03/20/09 11:26 PM
PA
moparacer Offline
moparacer  Offline
PA
I got years and years out of WalMart Tech 2000.....
Even ran it one time in my dragster after a all night thrash to fix it and wally world was the only place open.
Finished out the year with it, tore it apart that winter to freshen it and it looked fine.....
67 Barracuda street/bracket car 11.27-119
68 Dart 502 BB 8.70s-152
414 cid SB Dragster 7.65-174
Re: Tranny Fluid Which one to use? [Re: moparacer] #196211
03/20/09 11:43 PM
03/20/09 11:43 PM
Weatherford, Texas
RapidusMaximus Offline
Weatherford, Texas
Type "F" here...like the Exxon brand when I can find it...put many passes on O'Reilly's store brand...
1968 Plymouth GTX
1974 Dodge P/U Long Bed Stepside 318
2019 Ram 2500 6.4, auto, 4WD
Re: Tranny Fluid Which one to use? [Re: RapidusMaximus] #196212
03/28/09 10:23 AM
03/28/09 10:23 AM
Akron, Ohio
ProSport Offline
ProSport  Offline
Akron, Ohio
Is there anything wrong with Dexmerc from Advance or Auto Zone? Should I switch back to Type F? Seems alot of you run type F, that's what I used to run til new tranny builder told me to run DexMerc.
