Re: Tranny Fluid Which one to use?
[Re: DavidDean]
#196194
01/18/09 01:04 AM
01/18/09 01:04 AM
Posts: 52,972 Romeo MI
MR_P_BODY
I use mobil1 syn with Lucas additive, runs about 20*-30*coooler than conventional ATF.Clutches and bands usually look good. 408 SB 6.09 @110 @2000DA
I have no idea what mine looks like inside... its been 4 years since I opened it up... its still working fine
[Re: dave571]
#196197
03/19/09 08:34 PM
03/19/09 08:34 PM
Posts: 1,545 Seattle, WA
375inStroke
Special needs person
Seattle, WA
...dexron 3 more than exceeds any specs your mopar trans would have had initially.
Newer fluids (like atf +4) are simply better fluids, with better heat properties etc..
I'm skeptical of this. We all know how they tell us the new oil specs exceed the requirements of the old oils, and that there isn't enough ZDDP in there for our flat tappet cams. What aren't they telling us about the new ATFs?
[Re: 540dust]
#196199
03/19/09 08:53 PM
03/19/09 08:53 PM
Posts: 17,918 Akron, Ohio
ProSport
Akron, Ohio
My tranny guy has me buy regular DexMerc from Advance or anywhere else.
[Re: 375inStroke]
#196200
03/20/09 01:11 AM
03/20/09 01:11 AM
Posts: 5,314 Carstairs, Alberta, Canada
dave571
Modern ATF's have to be better, because the operating demands of newer applications are much higher. 6 speed autos in cars, Bigger trucks than ever, more power, and of course the fact that no one in the world seems to want to cruise at less than 10 over the speed limit regardless of how big a load they are hauling
[Re: mopar376d]
#196203
03/20/09 07:33 AM
03/20/09 07:33 AM
Type F
[Re: Michael]
#196210
03/20/09 11:26 PM
03/20/09 11:26 PM
Posts: 2,510 PA
moparacer
PA
I got years and years out of WalMart Tech 2000.....
Even ran it one time in my dragster after a all night thrash to fix it and wally world was the only place open.
Finished out the year with it, tore it apart that winter to freshen it and it looked fine.....
67 Barracuda street/bracket car 11.27-119 68 Dart 502 BB 8.70s-152 414 cid SB Dragster 7.65-174
[Re: moparacer]
#196211
03/20/09 11:43 PM
03/20/09 11:43 PM
Posts: 2,412 Weatherford, Texas
RapidusMaximus
Weatherford, Texas
Type "F" here...like the Exxon brand when I can find it...put many passes on O'Reilly's store brand...
1968 Plymouth GTX 1974 Dodge P/U Long Bed Stepside 318 2019 Ram 2500 6.4, auto, 4WD
[Re: RapidusMaximus]
#196212
03/28/09 10:23 AM
03/28/09 10:23 AM
ProSport
Akron, Ohio
Is there anything wrong with Dexmerc from Advance or Auto Zone? Should I switch back to Type F? Seems alot of you run type F, that's what I used to run til new tranny builder told me to run DexMerc.
