Dana 60 question? #1960773
12/01/15 09:42 AM
12/01/15 09:42 AM
Finalnd, Perkele
jyrki Offline OP
jyrki  Offline OP
Finalnd, Perkele
I'm building a Dana 60 for a '71 cuda. The starting point is some van axle with way greater offset than in a passanger car. I need to know how much longer the axle is on the drivers side than on the passanger side? And what is the axle tube length difference, how much is the pinion offset from center to the passanger side?
Plynouth VIP '67 TT IC EFI
Re: Dana 60 question? [Re: jyrki] #1960824
12/01/15 12:04 PM
12/01/15 12:04 PM
Polson, MT
DoctorDiff Offline
DoctorDiff  Offline
Polson, MT
Make the driver's side tube and axle 1 3/8" longer than the passenger's side. This will yield a stock Mopar passenger car (1 3/16") pinion offset.
My calculator below will figure housing/axle dimensions for most popular rearends in stock and custom configurations:
http://www.doctordiff.com/axle-calculator/
Re: Dana 60 question? [Re: jyrki] #1961069
12/01/15 04:53 PM
12/01/15 04:53 PM
Are you wanting the stock E body widths and measurements? If so hopefully someone will post them for you luck If your wanting to use it with wider wheels and tires then it can be narrowed to what ever width you want or need thumbs
Re: Dana 60 question? [Re: DoctorDiff] #1961073
12/01/15 04:56 PM
12/01/15 04:56 PM
Carson City, Nevada
Biginchmopar Offline
Carson City, Nevada
iagree
Dr. Diffs Calculator works AWESOME!
Re: Dana 60 question? [Re: jyrki] #1961535
12/02/15 04:50 AM
12/02/15 04:50 AM
Finalnd, Perkele
jyrki Offline OP
jyrki  Offline OP
Finalnd, Perkele
Thanks doctordiff!
The axle will be wider than stock, 63.8" from wheel flange to wheel flange, use new big ford ends and wilwood 11" (2.5") discs.
