Dana 60 question?
#1960773
12/01/15 09:42 AM
12/01/15 09:42 AM
Posts: 2,933 Finalnd, Perkele
jyrki
Finalnd, Perkele
I'm building a Dana 60 for a '71 cuda. The starting point is some van axle with way greater offset than in a passanger car. I need to know how much longer the axle is on the drivers side than on the passanger side? And what is the axle tube length difference, how much is the pinion offset from center to the passanger side?
Plynouth VIP '67 TT IC EFI
Re: Dana 60 question?
[Re: jyrki]
#1960824
12/01/15 12:04 PM
12/01/15 12:04 PM
Posts: 8,016 Polson, MT
DoctorDiff
Polson, MT
Make the driver's side tube and axle 1 3/8" longer than the passenger's side. This will yield a stock Mopar passenger car (1 3/16") pinion offset. My calculator below will figure housing/axle dimensions for most popular rearends in stock and custom configurations: http://www.doctordiff.com/axle-calculator/
[Re: jyrki]
#1961535
12/02/15 04:50 AM
12/02/15 04:50 AM
jyrki
Finalnd, Perkele
Thanks doctordiff! The axle will be wider than stock, 63.8" from wheel flange to wheel flange, use new big ford ends and wilwood 11" (2.5") discs.
