Door hinge re-pin
#1956571
11/23/15 05:44 PM
11/23/15 05:44 PM
Posts: 1,107 Lynch Road
mro
Lynch Road
69 RR, Popped out the original pins. Do I drill the holes to take the bushings and then use the original pins or do I do something else. The kit came with 2 new pins and 4 bushings. Thanks.
68 Satellite Wagon and a few other ones
Re: Door hinge re-pin
[Re: IMGTX]
#1959135
11/28/15 09:59 AM
11/28/15 09:59 AM
mro
Lynch Road
The upper hinges are a breeze. The bottoms - I don't see how to do this without drilling them - which is not a problem - BUT the bushings are to thick to put on the inner bracket. Is the idea to drill both lower parts and bushing it from the top?
[Re: mro]
#1959688
11/29/15 01:59 PM
11/29/15 01:59 PM
Posts: 9,826 MI, usa
dvw
MI, usa
Drill them. I've even used GM pick-up truck kits to repair them. Drill the hole for a snug press fit. Use a 5/16" bolt & nut, 2 flat washers, and a 13mm socket as a receiver. The socket will allow the bushing to be pressed through the hole in the hinge. Doug
[Re: IMGTX]
#1960418
11/30/15 08:24 PM
11/30/15 08:24 PM
Posts: 955 Chicago
PurpleBeeper
Chicago
If the holes are round I use them as is but most are worn to oval shape and need bushings.
Bushings go on the inner bracket.
I have a drill bit long enough to go all the way through both sides. This keeps them straighter when installed.
Place the bushings with the flange side toward the outside.
If by some chance the outer bracket holes are worn you have to weld and drill them round. If the pin won't retain then you will have to tack weld the top in place.
Sounds a lot harder then it actually is. Yep.... what he said
70 Roadrunner convt. street car
440+6, NOS, 4-spd, SS springs
'96 Mustang GT convt. street car
'04 4.6 SOHC, NOS, auto, lowered
"Officer, that button is for short on-ramps"
