King Bearings #1960082
11/30/15 02:24 AM
11/30/15 02:24 AM
Lowes
steve660 Offline OP
steve660  Offline OP
Lowes
Anyone on here a King bearing distributor?
PSO headed 632 from MM. Cracked cylinder, loose valve seats, low oil pressure, low cylinder pressure.
..... Now its a door stop....
Re: King Bearings [Re: steve660] #1960245
11/30/15 03:05 PM
11/30/15 03:05 PM
Lowes
steve660 Offline OP
steve660  Offline OP
Lowes
OK...
Re: King Bearings [Re: steve660] #1960250
11/30/15 03:10 PM
11/30/15 03:10 PM
Columbia, CT
moper Offline
moper  Offline
Columbia, CT
No offense, but are we supposed to guess which engine you're working with? The catalog's online, and you can always use the Summit site if you really can't figure out the King website.
Re: King Bearings [Re: moper] #1960292
11/30/15 04:28 PM
11/30/15 04:28 PM
Lowes
steve660 Offline OP
steve660  Offline OP
Lowes
...any dealers, venders on here???
Re: King Bearings [Re: steve660] #1960299
11/30/15 04:46 PM
11/30/15 04:46 PM
P
Porter67 Offline
Porter67  Offline
P
Its pretty easy, use google or any search engine to determine your needs, hit amazon or ebay for the good price, order and in 2-3 days you got your bearings.
Re: King Bearings [Re: steve660] #1960314
11/30/15 05:12 PM
11/30/15 05:12 PM
an8sec70cuda Offline
Guess you found the source of the problem?
CHIP
'06 GMC 2500HD LBZ Duramax
Re: King Bearings [Re: an8sec70cuda] #1960479
11/30/15 10:26 PM
11/30/15 10:26 PM
Lowes
steve660 Offline OP
steve660  Offline OP
Lowes
I think we both know the ROOT source of the problem.
The bearings looked just like the oil pump ring, loaded with aluminum chunks.
At least it was all Aluminum and not steel. Crank looks good.
