King Bearings
#1960082
11/30/15 02:24 AM
11/30/15 02:24 AM
Posts: 289 Lowes
steve660
Lowes
Anyone on here a King bearing distributor?
PSO headed 632 from MM. Cracked cylinder, loose valve seats, low oil pressure, low cylinder pressure. ..... Now its a door stop....
Re: King Bearings
[Re: steve660]
#1960245
11/30/15 03:05 PM
11/30/15 03:05 PM
Posts: 289 Lowes
steve660
Lowes
OK...
Re: King Bearings
[Re: steve660]
#1960250
11/30/15 03:10 PM
11/30/15 03:10 PM
Posts: 12,675 Columbia, CT
moper
Columbia, CT
No offense, but are we supposed to guess which engine you're working with? The catalog's online, and you can always use the Summit site if you really can't figure out the King website.
Re: King Bearings
[Re: moper]
#1960292
11/30/15 04:28 PM
11/30/15 04:28 PM
Posts: 289 Lowes
steve660
Lowes
...any dealers, venders on here???
Re: King Bearings
[Re: steve660]
#1960314
11/30/15 05:12 PM
11/30/15 05:12 PM
Posts: 13,369 Marion, South Carolina [><]
an8sec70cuda
Guess you found the source of the problem?
Re: King Bearings
[Re: an8sec70cuda]
#1960479
11/30/15 10:26 PM
11/30/15 10:26 PM
Posts: 289 Lowes
steve660
Lowes
Guess you found the source of the problem? I think we both know the ROOT source of the problem. The bearings looked just like the oil pump ring, loaded with aluminum chunks. At least it was all Aluminum and not steel. Crank looks good.
