question on 73 Satellite front disc brake setup #1960197
11/30/15 01:10 PM
11/30/15 01:10 PM
MD
75dusted Offline OP
75dusted  Offline OP
MD
A 73 Plymouth Satellite front disc brake setup including spindles , what other year b-bodys will these work on and fit, 69?
Re: question on 73 Satellite front disc brake setup [Re: 75dusted] #1960209
11/30/15 01:36 PM
11/30/15 01:36 PM
AndyF Offline
AndyF  Offline
The knuckles will fit on most anything as will the rotors and caliper brackets. The calipers usually aren't used on any swap since the hose placement will be wrong.
Re: question on 73 Satellite front disc brake setup [Re: 75dusted] #1960327
11/30/15 05:41 PM
11/30/15 05:41 PM
IMGTX Offline
IMGTX  Offline
That car uses an Isolated K frame.
IIRC the Knuckles are about 3/4" taller than the non isolated K frame cars. The non isolated cars are All A&E body and 72 and older B bodies. Basically any car that may have drum brakes Except C bodies and Trucks. While they will fit older cars it will effect the alignment.
Those are probably Pin type Calipers and are used in a bazillion cars so they aren't that rare.
The Calipers will fit the Early cars with Disk brake knuckles and brackets but as said they will not use a factory hose. You can however improvise if doing a swap.
Re: question on 73 Satellite front disc brake setup [Re: 75dusted] #1960420
11/30/15 08:32 PM
11/30/15 08:32 PM
Frederick, MD
71charger Offline
71charger  Offline
Frederick, MD
I believe them to be the same knuckles as used on the '77 Volare I got my disk brakes off of. I switched the calipers to the rear and used '73 Charger brake hoses and it all fit great.
Re: question on 73 Satellite front disc brake setup [Re: 71charger] #1960454
11/30/15 09:16 PM
11/30/15 09:16 PM
IMGTX Offline
IMGTX  Offline
Here is a picture of the difference. It isn't much and not very noticeable if you don't have two side by side.
Ehrenberg did a brake swap article here.
http://www.moparaction.com/Tech/archive/disc-main.html
As well as AR Engineering here.
http://arengineering.com/tech/mopar-musclecar-brake-upgrade/
