Rear End Squareing on A-body #1959691
11/29/15 02:06 PM
11/29/15 02:06 PM
corpus christi tex
Cheatham Offline OP
Cheatham  Offline OP
corpus christi tex
Ladder bar back halfed, iv used the trans crossmember and got it aligned, but if i try another location like the front leaf spring mount i get almost a 1/4in difference, where else is a good reference to measure from ? i also have Bobs Pro Fab tube and rack K-member.
Re: Rear End Squareing on A-body [Re: Cheatham] #1959695
11/29/15 02:12 PM
11/29/15 02:12 PM
Charlotte, North Carolina
sgcuda Offline
sgcuda  Offline
Check squareness from the trans crossmember to the ladder bar crossmember. If square, go from the ladder bar crossmember to the rear axle.
[image][/image]
Re: Rear End Squareing on A-body [Re: sgcuda] #1959699
11/29/15 02:19 PM
11/29/15 02:19 PM
corpus christi tex
Cheatham Offline OP
Cheatham  Offline OP
corpus christi tex
that was how the ladder bar X member was measured and installed off of was the tranny X member, im just getting picky about the settings making sure.
Re: Rear End Squareing on A-body [Re: Cheatham] #1959708
11/29/15 02:32 PM
11/29/15 02:32 PM
sgcuda Offline
sgcuda  Offline
Are you going in a X for measurements? That will tell you if square. The old leaf spring front mounts might be twisted up if you were racing it with leafs in it.
[image][/image]
Re: Rear End Squareing on A-body [Re: sgcuda] #1959729
11/29/15 03:05 PM
11/29/15 03:05 PM
^^^that^^^ cuz a parallelograms' legs will measure out equal but ain't square
Re: Rear End Squareing on A-body [Re: Cheatham] #1959973
11/29/15 11:20 PM
11/29/15 11:20 PM
Minnesota, USA
humpty Offline
humpty  Offline
Minnesota, USA
Every alignment guy I've worked with suggests eyeballing the rear for alignment. Roll the car straight forward (enough to get the car to settle) then look for an uneven reveal on the rear tire sidewalls by looking from the rear down each side of the car. Not very scientific but when you consider all the potential variables "square" is a relative term.
Re: Rear End Squareing on A-body [Re: Cheatham] #1959982
11/29/15 11:34 PM
11/29/15 11:34 PM
ky
68roadrunner Offline
ky
i have a laser in the end of a level, lay it across the rear sidewall shooting at the front. measure from where the laser lands over to the end of the spindle, on each side
Re: Rear End Squareing on A-body [Re: 68roadrunner] #1960016
11/30/15 12:16 AM
11/30/15 12:16 AM
Minnesota, USA
humpty Offline
humpty  Offline
Minnesota, USA
That's a great idea!
Re: Rear End Squareing on A-body [Re: 68roadrunner] #1960192
11/30/15 12:58 PM
11/30/15 12:58 PM
Lynchburg, VA
Leon441 Offline
Leon441  Offline
Lynchburg, VA
This is how I do it. But, the rear has to be center or this still does not work.
Re: Rear End Squareing on A-body [Re: Leon441] #1960208
11/30/15 01:35 PM
11/30/15 01:35 PM
Mt Morris Michigan
mopar dave Offline
mopar dave  Offline
Mt Morris Michigan
thats how i did mine as well.
