Re: Rear End Squareing on A-body
[Re: sgcuda]
#1959699
11/29/15 02:19 PM
11/29/15 02:19 PM
Posts: 456 corpus christi tex
Cheatham
corpus christi tex
Check squareness from the trans crossmember to the ladder bar crossmember. If square, go from the ladder bar crossmember to the rear axle. that was how the ladder bar X member was measured and installed off of was the tranny X member, im just getting picky about the settings making sure.
[Re: Cheatham]
#1959708
11/29/15 02:32 PM
11/29/15 02:32 PM
Posts: 4,243 Charlotte, North Carolina
sgcuda
Are you going in a X for measurements? That will tell you if square. The old leaf spring front mounts might be twisted up if you were racing it with leafs in it.
[image][/image]
[Re: sgcuda]
#1959729
11/29/15 03:05 PM
11/29/15 03:05 PM
RapidRobert
^^^that^^^ cuz a parallelograms' legs will measure out equal but ain't square
[Re: 68roadrunner]
#1960192
11/30/15 12:58 PM
11/30/15 12:58 PM
Posts: 4,330 Lynchburg, VA
Leon441
Lynchburg, VA
i have a laser in the end of a level, lay it across the rear sidewall shooting at the front. measure from where the laser lands over to the end of the spindle, on each side This is how I do it. But, the rear has to be center or this still does not work.
