Re: Pushrod question
[Re: Deepockets]
#1958883
11/27/15 07:12 PM
11/27/15 07:12 PM
Posts: 4,457 Washington
madscientist
Washington
What difference does it make? How can the ends get out? I can't think of a reason why a one piece design would be stronger or better.
[Re: madscientist]
#1959075
11/28/15 02:08 AM
11/28/15 02:08 AM
RapidRobert
What difference does it make? that is what he is asking, is there a difference/preference. I had the MP cut to fit ones that you then press in the ends & no issues.
[Re: RapidRobert]
#1959085
11/28/15 02:36 AM
11/28/15 02:36 AM
Posts: 43,157 Bend,OR USA
Cab_Burge
The Manton Series 5 will take way more abuse, lack of lubrication at high RPM, than any of the Smith Bros or any of the other comparable priced brands will Been there , done that OP, is the Trend brand a true one piece pushrod If so are yours for pushrod oiling or are they solid like the stock OEM Mopars are ?
[Re: mopar dave]
#1959367
11/28/15 07:05 PM
11/28/15 07:05 PM
Posts: 1,267 North, Alabama
D-50
North, Alabama
I gave $178.00 for my Manton Series 4 11/32 x.120 wall push rods 4 yrs. ago. I guess they have gone up a bunch since then.
1.33 60 ft,6.21 at 110.59 in the 1/8, pump gas small block,2950lbs,drag radials,mufflers and driven to track ...
