plug wires? #1958126
11/26/15 03:24 AM
11/26/15 03:24 AM
Toronto, Canada
dirtybee Offline OP
dirtybee  Offline OP
Toronto, Canada
Hi there, just wondering how often people change high performance spark plug wires?
Re: plug wires? [Re: dirtybee] #1958254
11/26/15 11:52 AM
11/26/15 11:52 AM
Mo.
racerx Offline
racerx  Offline
Mo.
when they go bad for me, I usually get bout two years out of the msd i'm trying the morose now wave
Re: plug wires? [Re: dirtybee] #1958383
11/26/15 03:12 PM
11/26/15 03:12 PM
off the grid
340B5 Offline
340B5  Offline
off the grid
I check them w/ a meter every once in a while. I've had my 409's for 14 years and they're back on my engine now.
Yeah, it's got a smallblock.
Re: plug wires? [Re: dirtybee] #1958426
11/26/15 04:54 PM
11/26/15 04:54 PM
It depends on a lot of things, how much you drive or race the car, how many times you remove the plugs from the motor and which type ignition and fuel you use shruggy I've had to replace expensive racing plug wires that ohm good but missed bad on the race car shockshruggyWhen in doubt(when having problems) change them out thumbs twocents
Re: plug wires? [Re: dirtybee] #1958513
11/26/15 09:13 PM
11/26/15 09:13 PM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
Firecore is who to see if you need a new set
Re: plug wires? [Re: dirtybee] #1958835
11/27/15 05:19 PM
11/27/15 05:19 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
My last set of Taylors were on at least 15 years.They were still working but looked bad and when I washed them it would miss a bit.Cant complain about that.We run them on everything.Had them on the 57 all the way up to the 80s Ram truck.Still run extras we had on the Harleys.Rocky
Chrysler Firepower
Re: plug wires? [Re: 340B5] #1958848
11/27/15 05:40 PM
11/27/15 05:40 PM
SoCal
Brian Hafliger Offline
SoCal
Yep, check ohm's new and test once in a while...
Brian Hafliger
Re: plug wires? [Re: dirtybee] #1960279
11/30/15 03:57 PM
11/30/15 03:57 PM
an8sec70cuda Online content
an8sec70cuda  Online Content
My MSD wires are close to 10 years old. I checked the ohms last year and they checked out fine. Ran a new best a couple months ago.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: plug wires? [Re: dirtybee] #1960852
12/01/15 12:34 PM
12/01/15 12:34 PM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
Most all quality plug wire will do the job.If your looking to replace them try the Firecores.We use and recommend them and as far as price,quality and service there's none better. up bow
