Oil pressure problem? #1958112
11/26/15 02:53 AM
11/26/15 02:53 AM
Texas
ChevyTS Offline OP
ChevyTS  Offline OP
Texas
How often are you supposed to change the oil on this brand of liquid filled gauge??
T & K Performance
Re: Oil pressure problem? [Re: ChevyTS] #1958131
11/26/15 03:28 AM
11/26/15 03:28 AM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
LOL...I think they recommend every 3500 inches smile
Re: Oil pressure problem? [Re: ChevyTS] #1958137
11/26/15 03:33 AM
11/26/15 03:33 AM
MR_P_BODY Offline
MR_P_BODY  Offline
I drain it regularly... just so I can read the gauge
wave
Re: Oil pressure problem? [Re: ChevyTS] #1958139
11/26/15 03:37 AM
11/26/15 03:37 AM
Texas
ChevyTS Offline OP
ChevyTS  Offline OP
Texas
I saw this on a truck in the shop the other day. I had to take a picture. wink
T & K Performance
Re: Oil pressure problem? [Re: ChevyTS] #1958143
11/26/15 03:43 AM
11/26/15 03:43 AM
MR_P_BODY Offline
MR_P_BODY  Offline
That is funny.. it has a leak.... LOL
wave
Re: Oil pressure problem? [Re: ChevyTS] #1958144
11/26/15 03:46 AM
11/26/15 03:46 AM
PA.
pittsburghracer Online work
"Little"John
pittsburghracer  Online Work
"Little"John
PA.
The issue isn't how often you change it as much as what weight oil should you use. LOl
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Oil pressure problem? [Re: ChevyTS] #1958167
11/26/15 04:39 AM
11/26/15 04:39 AM
The new liquid filled gauges work whistling grin
Re: Oil pressure problem? [Re: Cab_Burge] #1958215
11/26/15 10:55 AM
11/26/15 10:55 AM
s.w.fl
bonefish Offline
bonefish  Offline
s.w.fl
I would just install a return line and ferget about it. whistling
Re: Oil pressure problem? [Re: bonefish] #1958236
11/26/15 11:14 AM
11/26/15 11:14 AM
MI, usa
dvw Offline
dvw  Offline
MI, usa
Make sure the return is at least -8
Doug
Re: Oil pressure problem? [Re: ChevyTS] #1958279
11/26/15 12:35 PM
11/26/15 12:35 PM
Az
Crizila Offline
Crizila  Offline
Az
Every 94,249 miles - and while you are at it, change the gauge.
Fastest 300
Re: Oil pressure problem? [Re: ChevyTS] #1958318
11/26/15 01:42 PM
11/26/15 01:42 PM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
Looks like the guys at the gauge place forgot to put the drain plug on the glass.
68 Barracuda Formula S 340
