Oil pressure problem?
#1958112
11/26/15 02:53 AM
11/26/15 02:53 AM
Posts: 576 Texas
ChevyTS
Texas
How often are you supposed to change the oil on this brand of liquid filled gauge??
T & K Performance
Re: Oil pressure problem?
[Re: ChevyTS]
#1958144
11/26/15 03:46 AM
11/26/15 03:46 AM
Posts: 20,174 PA.
pittsburghracer
"Little"John
"Little"John
PA.
How often are you supposed to change the oil on this brand of liquid filled gauge?? The issue isn't how often you change it as much as what weight oil should you use. LOl
[Re: bonefish]
#1958236
11/26/15 11:14 AM
11/26/15 11:14 AM
Posts: 9,837 MI, usa
dvw
MI, usa
I would just install a return line and ferget about it. Make sure the return is at least -8 Doug
[Re: ChevyTS]
#1958279
11/26/15 12:35 PM
11/26/15 12:35 PM
Posts: 7,506 Az
Crizila
Az
Every 94,249 miles - and while you are at it, change the gauge.
Fastest 300
[Re: ChevyTS]
#1958318
11/26/15 01:42 PM
11/26/15 01:42 PM
Posts: 8,027 Tulsa OK
Bad340fish
Tulsa OK
Looks like the guys at the gauge place forgot to put the drain plug on the glass.
68 Barracuda Formula S 340
