Re: Motor Installation From Underneath [Re: Quikshft] #195753
01/21/09 11:38 PM
01/21/09 11:38 PM
Chesapeake, Va
4aThrill Offline
4aThrill  Offline
Chesapeake, Va
So has anyone had any problems on changing out the starter by putting the engine in this way?
Meaning; I know that not everyone has stock exhaust manifolds on their car. So with that being said people who do have aftermarket headers on and putting the engine in from under the car. Has anyone ran into any problems in replacing the starter other than removing sparkplugs, header bolts, steering linkage, jacking/loosing up the engine, and moving the header around for enough space for the starter to drop out.
Re: Motor Installation From Underneath [Re: 4aThrill] #195754
01/22/09 09:01 AM
01/22/09 09:01 AM
MO
cdp Offline
cdp  Offline
MO
I had an MP one when installing the 340 in my dart. No issues.
Re: Motor Installation From Underneath [Re: cdp] #195755
01/22/09 08:17 PM
01/22/09 08:17 PM
Chesapeake, Va
4aThrill Offline
4aThrill  Offline
Chesapeake, Va
thankx for the info
Re: Motor Installation From Underneath [Re: LYNCHROAD69.5] #195756
01/30/09 09:52 PM
01/30/09 09:52 PM
St Louis, MO 63026
convx4 Offline
convx4  Offline
St Louis, MO 63026
I did my slant six 70 swinger from underneath. Worked great.
Re: Motor Installation From Underneath [Re: convx4] #195757
01/30/09 10:14 PM
01/30/09 10:14 PM
Iowa
burdar Online work
Owen's Dad
burdar  Online Work
Owen's Dad
Iowa
I see that people are using cherry pickers to lift the front end up. I was planning on taking the car to a shop just to use there hoist. That way I could come straight down with the body instead of at an angle. Apparently this isn't an issue then?
Re: Motor Installation From Underneath [Re: burdar] #195758
01/31/09 08:50 AM
01/31/09 08:50 AM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
Engine crane works great.
Re: Motor Installation From Underneath [Re: Challenger 1] #195759
02/01/09 09:52 AM
02/01/09 09:52 AM
Essex, Ont., Canada
Fishmarket Offline
Fishmarket  Offline
Essex, Ont., Canada
I've done this, but one thing I would suggest is to have the engine/trans on something with castors. Much easier to wiggle it in to the proper location than using stands. I had the lower control arms mounted with ball joints and had no issues there either.
Good luck!
1972 Plymouth Cuda 340 4 speed 1971 Plymouth Road Runner 383 Auto 1970 Plymouth Duster /6 Auto
Re: Motor Installation From Underneath [Re: burdar] #195760
02/01/09 06:01 PM
02/01/09 06:01 PM
I have a 4 post lift and a cherry picker and used both of them th install the Hemi in my 66 Coronet.
Unfortunately, the lip for the drip pans on the lift wheel runners were too wide to allow the engine to fit between them. I took my die grinder and "relieved" those area of the drip pan flanges of their excess metal so it would fit. If I had nor been in the middle of thin install I would have just used the cherry picker and floor jacks.
Re: Motor Installation From Underneath [Re: LYNCHROAD69.5] #195761
02/03/09 09:54 AM
02/03/09 09:54 AM
Jacksonville, Fl
426runner Offline
426runner  Offline
Jacksonville, Fl
Later, Sandy '70 HEMI Road Runner B5/B5, 4 spd "Sandy's Garage" on Facebook
Re: Motor Installation From Underneath [Re: 426runner] #195762
02/03/09 12:00 PM
02/03/09 12:00 PM
West Coast, CA
Troy Offline
Troy  Offline
West Coast, CA
These things were real complete when they installed them.....
....there is nothing like driving my 1968 Hemi Dart around town and having people looking at you like you're nuts!!
Re: Motor Installation From Underneath [Re: Challenger 1] #195763
02/03/09 12:50 PM
02/03/09 12:50 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
pardon my ignorance for i have never done this method before either, but why even have the front end installed and just do it after the "K" is bolted up?
You could install the suspension after the engine is installed but it's easier to get to everything before hand. That way you don't take the chance of messing up the paint on the body if you slip with a wrench.
The factory had most everything installed on on the k-member before it was installed in the car.
It's much easier to install the K without the lower arms hanging there and it is no trouble to install them after the K is in place. No risk in nicking the paint IMO. Done it a couple times.
Exactly , I don't know anyone that drops the K frame and motor assembly to do front end work ...
Re: Motor Installation From Underneath [Re: 426runner] #195764
02/03/09 08:07 PM
02/03/09 08:07 PM
Hunt Valley, Maryland
1fastrunner Offline
1fastrunner  Offline
Wow, that was fast! I sure could use some help dropping mine out. This will be my first time, I saw 3 guys with an audience of at least two.
Re: Motor Installation From Underneath [Re: 1fastrunner] #195765
02/04/09 12:57 AM
02/04/09 12:57 AM
Sacramento,California
JRepucci Offline
JRepucci  Offline
The more parts on the better.... remember to torque everything to spec.
