stock lower CA for use with Coilovers #1955500
11/21/15 08:13 PM
11/21/15 08:13 PM
west palm beach, florida
modelmakerinc Offline OP
Guys being on a budget I would like to make gradual upgrades to my front suspension (67 B-body) with out having to buy a KIT from RMS I would like to go incrementally.
I am trying to find the parts to convert the LCA pivot to remove the torsions and go coilovers, I will eventually do the k member, tubular LCA and R&P steering but for now just uppers and coilovers but I need to adress the pivot. thanks
Henry
Exceptional Architectural, Yacht and Automotive scale models. e-mail modelmakerinc@att.net for a portfolio review. www.modelmakerinc.com
Re: stock lower CA for use with Coilovers [Re: modelmakerinc] #1955529
11/21/15 08:49 PM
11/21/15 08:49 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: stock lower CA for use with Coilovers [Re: modelmakerinc] #1955615
11/22/15 12:04 AM
11/22/15 12:04 AM
Huntsville, AL
Airwoofer Offline
Airwoofer  Offline
Huntsville, AL
There are pictures out there of people who put a end washer on the LCA where the torsion bar used to interface. Tied the end washer onto the pivot.
Ask HDK about clearing things on the frame and how the shock needs to be located. He has the lower shock mount out further on his LCA. You need room for the spring.
Re: stock lower CA for use with Coilovers [Re: modelmakerinc] #1955693
11/22/15 04:15 AM
11/22/15 04:15 AM
North Alabama
Monte_Smith Offline
Monte_Smith  Offline
North Alabama
Cheap and dirty way........get some old torsion bars, hack the end off and weld them to a plate. Make a tab on the frame to bolt this plate to. All you are trying to do is support control arm on both sides. Weld some tabs on control arm wherever they need to be to mount bottom of shock. Some use the Magnum Force adapters that use the stock top shock mount. I always just welded a piece of tubing across the inside of shock tower and hung two tabs on it for the top mount
Re: stock lower CA for use with Coilovers [Re: modelmakerinc] #1955699
11/22/15 05:32 AM
11/22/15 05:32 AM
Huntsville, AL
Airwoofer Offline
Airwoofer  Offline
Huntsville, AL
That sounds awful heavy though. Here is a tubular LCA HDK made for my Demon.
http://s1377.photobucket.com/user/LSXSONOMA/media/IMG_4184_zpsxhcpn6bb.jpg.html
Re: stock lower CA for use with Coilovers [Re: modelmakerinc] #1955855
11/22/15 03:36 PM
11/22/15 03:36 PM
North Alabama
Monte_Smith Offline
Monte_Smith  Offline
North Alabama
It is heavy...........same as stock. He just said he wanted to lose the torsion bars on the cheap
Re: stock lower CA for use with Coilovers [Re: Monte_Smith] #1956077
11/22/15 09:04 PM
11/22/15 09:04 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
Same thing Roy Hill did on his Duster many moons ago.
Re: stock lower CA for use with Coilovers [Re: modelmakerinc] #1956161
11/22/15 11:12 PM
11/22/15 11:12 PM
Thanks guys, lm going to put a little green together and buy the upper and lower control arms from HDK. I like the support bracket for the LCA pivot, it makes the pivot a double shear. And I can keep my stock K and steering.
Re: stock lower CA for use with Coilovers [Re: modelmakerinc] #1956193
11/22/15 11:53 PM
11/22/15 11:53 PM
Charleston
sixpackgut Offline
Drag Week Mod Champion
sixpackgut  Offline
Charleston
I just did this and lost 12lbs out of my front susp.
Re: stock lower CA for use with Coilovers [Re: sixpackgut] #1956426
11/23/15 12:58 PM
11/23/15 12:58 PM
Tucson, Arizona
clonestocker Offline
Tucson, Arizona
sixpackgut,
Where did you get your upper shock mounts? thx matt
[img] [/img]
Re: stock lower CA for use with Coilovers [Re: modelmakerinc] #1956481
11/23/15 03:17 PM
11/23/15 03:17 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
??? No front brakes ???
Re: stock lower CA for use with Coilovers [Re: Stanton] #1956484
11/23/15 03:23 PM
11/23/15 03:23 PM
Charleston
sixpackgut Offline
sixpackgut  Offline
Charleston
I got 2 lbs each out of the control arms
3 lbs each side T bar vs coil spring an shock nuts
1 lb out of each spindle
1/2 lb using regular washers instead of the heavy strut washers
Magnumforce sells the shock mounts. I have also head Afco sell a direct fit coil over shock which could save you money on the mounts
Re: stock lower CA for use with Coilovers [Re: Stanton] #1956516
11/23/15 04:25 PM
11/23/15 04:25 PM
North Alabama
Monte_Smith Offline
Monte_Smith  Offline
North Alabama
That's a Wilwood caliper bracket bolted on there
Re: stock lower CA for use with Coilovers [Re: modelmakerinc] #1956663
11/23/15 08:05 PM
11/23/15 08:05 PM
gregsdart Offline
gregsdart  Offline
I have been running coilovers with stock lower control arms in my street 65 Dart, no extra support. The strut rods provide a lot of support from twisting of the lower control arms, so IMHO there is enough strength with the stock deal to get by. I chose to put more support on the race Dart, supporting both sides
Re: stock lower CA for use with Coilovers [Re: modelmakerinc] #1956867
11/24/15 12:59 AM
11/24/15 12:59 AM
Huntsville, AL
Airwoofer Offline
Airwoofer  Offline
Huntsville, AL
I have eyeballed my SBJ stock spindles and the extra metal for that pound.
Man, the technology has been there for over a decade to make these with laser sintered titanium (metal 3-D printing) with forged properties, just the way we want, then they machine them to fit like normal. Sucks being poor.
Re: stock lower CA for use with Coilovers [Re: sixpackgut] #1962940
12/04/15 05:20 AM
12/04/15 05:20 AM
New Lenox IL
cudadon Offline
cudadon  Offline
New Lenox IL
sixpackgut which spindles are those?
What did you do to the lower ca? Sorry I didn't notice what you did.
Thanks, Don
