fender tag #1956369
11/23/15 10:55 AM
11/23/15 10:55 AM
kennedy,ny
bballfan1 Offline OP
kennedy,ny
can i figure out what options a car came with with just the vin and door jam sticker?
thanks
Re: fender tag [Re: bballfan1] #1956375
11/23/15 11:11 AM
11/23/15 11:11 AM
Abilene, Texas
fastmark Offline
fastmark  Offline
Abilene, Texas
No. Only body style and engine size and hp.
Re: fender tag [Re: bballfan1] #1956411
11/23/15 12:27 PM
11/23/15 12:27 PM
Stuttgart, Arkansas
rickseeman Offline
rickseeman  Offline
Stuttgart, Arkansas
thanks
Depends what year it is.
2011 Drag Pak Challenger
Re: fender tag [Re: rickseeman] #1957596
11/25/15 11:21 AM
11/25/15 11:21 AM
kennedy,ny
kennedy,ny
1972
Re: fender tag [Re: bballfan1] #1957611
11/25/15 11:54 AM
11/25/15 11:54 AM
Harlan, Iowa
69CoronetRT Offline
69CoronetRT  Offline
Harlan, Iowa
Depending on the, very limited, application there are some things that can be derived from just the VIN.
For example: If the VIN is WH23H2A, we know it's a '72 340 Charger and therefore has the A57 Rallye package option. We know this because the 340 only came with A57. There may be more but that's one I could think of off the top of my head.
As far as PS, PB, A/C and things like that; no you can't tell those options from the VIN.
Seeking:
1969 St. Louis plant VINs, SPD, and VONs.
Over 2,000 thanks to you!
Re: fender tag [Re: bballfan1] #1957649
11/25/15 01:28 PM
11/25/15 01:28 PM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
69CoronetRT
Good answer.
Correct, the door tag/VIN will only give you the body type, trim level, model year, engine type, assembly plant, and VIN sequence number.
Engine size CAN dictate the options that were associated with any package items that were included with that particular engine. For example, all 1970 340 A-body cars came standard with front disc brakes. Beyond that you are SOL.
