Hemi super stock dart Windows #1955806
11/22/15 02:14 PM
11/22/15 02:14 PM
Hilltown Pa
1967dartgt Offline OP
Hilltown Pa
Does anyone have drawing of the system they used in the door windows? I know they used seat belts, but was trying to find how it's done.
Anyone reproduce kits? Thinking of doing it to loose weight on my car.
Brett Miller W9 cnc'd heads
STR Chassis fabraction
Re: Hemi super stock dart Windows [Re: 1967dartgt] #1955816
11/22/15 02:30 PM
11/22/15 02:30 PM
baldwinsville new york
a493demon Offline
a493demon  Offline
Think someone just had a video on Facebook .
Re: Hemi super stock dart Windows [Re: 1967dartgt] #1955817
11/22/15 02:30 PM
11/22/15 02:30 PM
s e mich
ro23car Offline
ro23car  Offline
s e mich
they just use a snap at the bottom of the door
Re: Hemi super stock dart Windows [Re: 1967dartgt] #1955826
11/22/15 02:40 PM
11/22/15 02:40 PM
a493demon Offline
a493demon  Offline
I just looked around and couldn't find it .
Re: Hemi super stock dart Windows [Re: 1967dartgt] #1955841
11/22/15 02:59 PM
11/22/15 02:59 PM
Fulton County, PA
CMcAllister Online content
Mr. Helpful
CMcAllister  Online Content
Mr. Helpful
Fulton County, PA
Did it on a Duster I had in another life. Seat belt strap bolted to the track mechanism attached to the bottom of the glass. Fold the outer end over and sew. Install a heavy duty snap and install the male half of the snap in the metal below the door panel. The door still had the OE arm rest. I ran it just behind that. Pretty simple. I wasn't trying to make it a perfect copy of the '68 cars.
Re: Hemi super stock dart Windows [Re: 1967dartgt] #1955870
11/22/15 03:58 PM
11/22/15 03:58 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
Here's my B Body. It ha snap at the top and one at the bottom.
Doug
Re: Hemi super stock dart Windows [Re: dvw] #1955884
11/22/15 04:25 PM
11/22/15 04:25 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
DAMN nice work there sir and are those formed lexan or?
Re: Hemi super stock dart Windows [Re: a493demon] #1955907
11/22/15 04:51 PM
11/22/15 04:51 PM
Akron, Ohio
ProSport Offline
ProSport  Offline
Akron, Ohio
I saw that yesterday, I'll try to find it.
Re: Hemi super stock dart Windows [Re: Thumperdart] #1956061
11/22/15 08:30 PM
11/22/15 08:30 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
No, Lexan was cut from 4'x8'sheet. The bottom has .060" aluminum angle bolted on to stiffen it up (1/8"). The door release is mounted on aluminum channel as well with a piece of 3/8" steel fuel line welded from the door release to the vent frame to keep the handle from flexing. A Home Depot closet door roller is modified to ride on the front of the vent channel to keep the window from tilting. Vent is Lexan also (1/4").
All cheap stuff. My 63 Dodge H/T was done the same way.
Doug
Re: Hemi super stock dart Windows [Re: 1967dartgt] #1956082
11/22/15 09:13 PM
11/22/15 09:13 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
All the ones I saw back in the day had both seat belt pieces. Pull the release and the window goes down, release with belt hooked to window. The tongue (male part) bolted to bottom of door.
Re: Hemi super stock dart Windows [Re: dvw] #1956083
11/22/15 09:16 PM
11/22/15 09:16 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
Doug
If you don't mind me asking how much does the car weight?
Re: Hemi super stock dart Windows [Re: 1967dartgt] #1956229
11/23/15 12:49 AM
11/23/15 12:49 AM
Hilltown Pa
Hilltown Pa
Doug, you just run it up through the felt and window?
Re: Hemi super stock dart Windows [Re: 1967dartgt] #1956231
11/23/15 12:56 AM
11/23/15 12:56 AM
MI, usa
dvw Offline
dvw  Offline
MI, usa
Yes, The 63 H/T was 3/16" since there were no frames. It seemed to seal well but at high speed the top of the windows would suck outward with air pressure. The 64 sedan has no issue.
Doug
Re: Hemi super stock dart Windows [Re: 1967dartgt] #1956410
11/23/15 12:26 PM
11/23/15 12:26 PM
Benton, IL.
DaveRS23 Offline
Special needs idiot
DaveRS23  Offline
Special needs idiot
Benton, IL.
If you are going to actually drive the car much, it is difficult to get the strap just right so that the window is up tight and you can still snap it. Also, even the tough seat belts can stretch just a bit over time allowing the window to drop a little bit.
I dealt with this by using clean used seat belts from the junk yard and attaching the window end of the belt to a loop of stiff elastic band. That way I had some give on the strap so that I could snap it easier when the window was up, and the window was always pulled up tight to the weatherstrip.
Master, again and still
Re: Hemi super stock dart Windows [Re: DaveRS23] #1956470
11/23/15 02:56 PM
11/23/15 02:56 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
That's the reason they used the lap buckle part, click it then pull up to tighten the belt
Re: Hemi super stock dart Windows [Re: Thumperdart] #1956517
11/23/15 04:26 PM
11/23/15 04:26 PM
Upstate NY
Bigcube Offline
Bigcube  Offline
Upstate NY
X2, Beautiful work! Question, what holds the window up?
Re: Hemi super stock dart Windows [Re: Bigcube] #1956532
11/23/15 04:56 PM
11/23/15 04:56 PM
Addison,IL
OUTLAWSSAA Offline
OUTLAWSSAA  Offline
Addison,IL
When you pull the strap down, then snap the button to the tab on the door.
Re: Hemi super stock dart Windows [Re: cudaman1969] #1956802
11/23/15 11:42 PM
11/23/15 11:42 PM
Benton, IL.
DaveRS23 Offline
Special needs idiot
DaveRS23  Offline
Special needs idiot
Benton, IL.
While I am no expert, I don't believe that the original 68 SS cars had buckles on the window lift belts. Here is a link to Mancini's old car that is at Mecum now. There are a couple of pics of the interior there. No buckles on the window lift belts on that Dart.
Besides, I tried the buckle. First, it really doesn't do a good job of pulling the window up after the belt goes around all those corners. Second, it is hard on the paint where the belt rubs. And lastly,that buckle flopping around the top of the door when the window is down, isn't cool.
The elastic and a snap is just a better way to go, in my opinion.
Re: Hemi super stock dart Windows [Re: DaveRS23] #1956823
11/24/15 12:04 AM
11/24/15 12:04 AM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
Race cars didn't run with the window down. I think 1970, West Virginia Hemi, the first time I noticed what held the window up. Of course he could have done that himself. Saw plenty of the Darts and Cudas in 68-69 but to busy looking at the engine LOL and wishing I had one of them. Still can't afford one!
Re: Hemi super stock dart Windows [Re: cudaman1969] #1956846
11/24/15 12:27 AM
11/24/15 12:27 AM
Benton, IL.
DaveRS23 Offline
Special needs idiot
DaveRS23  Offline
Special needs idiot
Benton, IL.
I can't afford a real one, either. So I built my own:
