fel-pro head gasket ?? #1956032
11/22/15 07:46 PM
11/22/15 07:46 PM
norcal
JLaSalle Offline OP
JLaSalle  Offline OP
norcal
So Im wondering if I can re-use my fel-pro blue 1039's after I torqued the alum. heads down,but had to pull them off a few days later?I found 1 bad cam lobe(roller) after the heads were torqued down.No impression from the wire ring in the head,and the gaskets will go back how they were on initially.
Planning on calling fel-pro tomorrow,but what's the consensus here?
1967 Coronet R/T
9.83 134mph. 470 cid st.6 heads
10x pro et track champion
Re: fel-pro head gasket ?? [Re: JLaSalle] #1956039
11/22/15 07:58 PM
11/22/15 07:58 PM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
I would use it.
Re: fel-pro head gasket ?? [Re: justinp61] #1956062
11/22/15 08:32 PM
11/22/15 08:32 PM
norcal
JLaSalle Offline OP
JLaSalle  Offline OP
norcal
Originally Posted By justinp61
I would use it.
Im inclined to.I've already 'crushed' the gasket though,and will spring for new ones if it's questionable.
1967 Coronet R/T
Re: fel-pro head gasket ?? [Re: JLaSalle] #1956066
11/22/15 08:47 PM
11/22/15 08:47 PM
Wichita
GY3 Offline
GY3  Offline
Wichita
I would NOT!
I had a failure of two recently and we're still trying to figure out why.
Torqued to spec., proper order, sequence of three, arp lube on arp bolts.
Both surfaces (head and block) freshly machined and confirmed square.
No more Felpro's for me!
Re: fel-pro head gasket ?? [Re: GY3] #1956206
11/23/15 12:15 AM
11/23/15 12:15 AM
I just had two FP failures too (wouldn't hold 15 psi in the cooling system (PRIOR) to fireup but in all fairness I did extensive cooling hole additions in the decks & I mighta messed up the deck (still ain't figured out what went wrong but I will). maybe I did not chamfer the holes and they needed to be chamfered. those FP's are cheap & I think I would be proactive & spring for new ones
Re: fel-pro head gasket ?? [Re: JLaSalle] #1956316
11/23/15 03:39 AM
11/23/15 03:39 AM
If that part number is for a SB Mopar I don't think I've ever reused them, if it is for BB I have reused them(8519, 1009 and some others part # mabye confused) after dyno testing and even after driving them on the street and reusing them. They showed no damage and they went back on the same side with the same side up with the same heads shruggy work
Re: fel-pro head gasket ?? [Re: Cab_Burge] #1956321
11/23/15 04:02 AM
11/23/15 04:02 AM
norcal
JLaSalle Offline OP
JLaSalle  Offline OP
norcal
Thanks everyone.Im surprised to hear of the failures,as Ive never had a problem with these gaskets at 13-1 in nearly 20 years of using them.I like to keep it simple and stick with what's been working.
Cab,thats encouraging.Appreciate it up
Re: fel-pro head gasket ?? [Re: JLaSalle] #1956341
11/23/15 07:09 AM
11/23/15 07:09 AM
Arizona
Chris'sBarracuda Offline
Arizona
Try the 1105's.. Basically the same gasket, but for wedge only.
The 1039's are for Wedge/Hemi...
Plus, the 1105 has much better construction..
15.5 : 1 never had a problem. wave
Chris.. coffee
Re: fel-pro head gasket ?? [Re: JLaSalle] #1956348
11/23/15 09:28 AM
11/23/15 09:28 AM
MI, usa
dvw Offline
dvw  Offline
MI, usa
I've reused them on my old 498 3 times over the course of a few seasons. 13.3-1 Indy head. Never had an issue.
Doug
Re: fel-pro head gasket ?? [Re: JLaSalle] #1956505
11/23/15 03:54 PM
11/23/15 03:54 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Lost a lobe on Pettis`s dyno years ago and re-used mine w/no issues after 7 years street/strip.......
Re: fel-pro head gasket ?? [Re: JLaSalle] #1956659
11/23/15 07:59 PM
11/23/15 07:59 PM
Windsor ,Ca.
K
Keith Richards Offline
K
Windsor ,Ca.
Re-use them Jeff and re-torque after a few heat cycles. You going out Sunday or headed to Vegas?
Re: fel-pro head gasket ?? [Re: Keith Richards] #1956683
11/23/15 08:35 PM
11/23/15 08:35 PM
norcal
JLaSalle Offline OP
JLaSalle  Offline OP
norcal
Hey Keith.Done runnin until next year.Gonna freshen my stuff and be ready,guns blazin,for next year.Gonna buy a box and play at the fling,too.Cant wait for that.
You gonna come out sunday and freeze your tail off?
Re: fel-pro head gasket ?? [Re: JLaSalle] #1956758
11/23/15 10:34 PM
11/23/15 10:34 PM
Windsor ,Ca.
K
K
Windsor ,Ca.
Yes I am hoping so, got to do some testing for next year and hopefully pop a wheelie or two in the process, been to loooong! The MH has a great heater so looking forward to camping as well. lol
