Re: piston ring filer
[Re: Moparnut426]
#195602
01/16/09 11:29 PM
01/16/09 11:29 PM
Posts: 43,127 Bend,OR USA
Cab_Burge
I don't know about the best but I do own a hand filer from Speed Pro and a electric one from Pro Form Both do the job but the electric one is way faster and easier Be careful on the electric one and when switching from the Moly top rings to the second cast iron ring, the cast iron rings are way softer than the top moly rings and it is real easy to make the gap to big Take your time on this procedure especially if you haven't done a set already on either type of ring filer File a little and check it, and and do that again until you get what sizes you want
[Re: Bob_Coomer]
#195607
01/17/09 04:45 PM
01/17/09 04:45 PM
Posts: 20,752 A collage of whims
topside
A collage of whims
Summit gets them from our factory. I'll sell you the same thing for $46.95. We have a lifetime warranty, even on the grinding disc. You can look us up on eBay (racecar tools) or see the website at area51groupllc.com. Ring grinders, valve spring testers, height mics, the best rod-bolt stretch indicator on the market, rearend setup tool kit, leakdown testers, cylinder head stands...discounts on multiple-tool orders, too. You won't find better bang for your buck.
[Re: b1dartsport]
#195611
01/17/09 10:48 PM
01/17/09 10:48 PM
Posts: 9,826 las vegas
70AARcuda
las vegas
bought mine from Ed Hamburger's for 340/360 only...paid less then 20 bucks..
I guess it has been awhile.
Tony
70 AARCuda Vitamin C 71 Dart Swinger 360 10.318 @ 128.22(10-04-14 Bakersfield) 71 Demon 360 10.666 @122.41 (01-29-17 @ Las Vegas) 71 Duster 408 (10.29 @ 127.86 3/16/19 Las Vegas)
[Re: 70AARcuda]
#195612
01/17/09 11:03 PM
01/17/09 11:03 PM
Posts: 6,257 gulfport, ms, west mi
rowin4
A little help full trick, if you use a hand crank filer, count the number of cranks to get the tolerance needed. Then repete for the rest of the rings. As said above, molly is harder than cast so more crank revolutions will be needed.
