still have to run a hotwire #1954051
11/19/15 12:28 AM
11/19/15 12:28 AM
las vegas,nv
mopar muscle7271 Offline OP
las vegas,nv
i have a 72 duster as well with a 383 in it with points,beside the dart i have.in order for it to start i have to run a hotwire from the postive side of the coil to postive side of battery.i have replaced the ignition switch and starter rely.I still have to run a hot wire in order to shut it on/off. any ideas what it could be still?
Re: still have to run a hotwire [Re: mopar muscle7271] #1954054
11/19/15 12:31 AM
11/19/15 12:31 AM
Fresno, CA
Jim_Lusk Offline
Jim_Lusk  Offline
Fresno, CA
Bad ballast perhaps. Poor connection at the bulkhead or ??
Re: still have to run a hotwire [Re: mopar muscle7271] #1954069
11/19/15 01:07 AM
11/19/15 01:07 AM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
AMMETER, or connections to or from, BTDT
twocents
Re: still have to run a hotwire [Re: Jim_Lusk] #1954075
11/19/15 01:15 AM
11/19/15 01:15 AM
it will crank OK but will not start until you jump directly from batt to coil? I would check the cranking voltage at the coil positive primary terminal with and without the jumper (& post what you get). do minimal cranking time for each check so the battery possibly getting run down a bit dont skew the readings. I would clean every terminal/connection from the battery in thru the bulkhead/to/thru ammeter/to ign sw (its connector) and the brown wire ign2 (cranking) circuit from the "ign2" ign sw terminal back out thru bulkhead & on to the coil positive primary to elim the voltage drop
Re: still have to run a hotwire [Re: RapidRobert] #1954078
11/19/15 01:18 AM
11/19/15 01:18 AM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
only other culprit I can think of is a blown fusible link
twocents beer
Re: still have to run a hotwire [Re: mopar muscle7271] #1954100
11/19/15 01:48 AM
11/19/15 01:48 AM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
TJP neither one of those will cause his problem. Those will cause a no crank not a no start.
Re: still have to run a hotwire [Re: mopar muscle7271] #1954140
11/19/15 03:33 AM
11/19/15 03:33 AM
WA
tman Offline
tman  Offline
WA
Still have not heard if ballast was checked. Does OP have the 2 or 4 prong ballast?
Re: still have to run a hotwire [Re: tman] #1954158
11/19/15 05:08 AM
11/19/15 05:08 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
Actually when cranking the eng the ballast is bypassed anyway. It sounds like a wireing problem if you already put a new ign switch in it. Check for voltage at the coil + while cranking. I you dont have volts there when cranking trace it back to the ign 2 terminal on the ign switch. Ron
Re: still have to run a hotwire [Re: mopar muscle7271] #1954293
11/19/15 02:35 PM
11/19/15 02:35 PM
Northern Calyfornua
Sxrxrnr Offline
Sxrxrnr  Offline
Northern Calyfornua
Check the female holes in the ignition switch to dash wiring connector. Suspect that you will find one or more has enlarged so that the male's from the ignition switch are wallering about in the females on the dash harness side and not making solid contact. .
With a very small bladed(like watch builder or eyeglasses size) screwdriver you can squeeze them a bit tighter, ensuring a tight fit. .
You should check and tighten all 5 of the larger gauge ones, blue, black, red, yellow and brown.
If not the problem this time, likely could be in the future. This is a miserable example of a Molex connector, as each time you separate it and reattach it, these holes will enlarge.
Re: still have to run a hotwire [Re: Sxrxrnr] #1954897
11/20/15 03:22 PM
11/20/15 03:22 PM
las vegas,nv
las vegas,nv
its a 2prong resistor, and i will look and see if they are and check wires.ill check the voltage as well,the coil is brand new as well.
Re: still have to run a hotwire [Re: mopar muscle7271] #1955821
11/22/15 02:34 PM
11/22/15 02:34 PM
check the cranking voltage at the coil positive primary terminal then check it (same way) at the downstream (brown wire) end of the ballast then stick a thin metal pin into the bulkhead & check that ign 2 circuit wire. with a jumper connect the neg lead of your VOM to the batt neg post & the red VOM lead on the (3) checks above. make each check brief/fast so as to not deplete the batt (wont hurt the batt but can skew the readings)
