440 source bears off #1954384
11/19/15 05:14 PM
11/19/15 05:14 PM
,Pa.
68dodge Offline OP
68dodge  Offline OP
,Pa.
Received my 512 stroker kit. Found out the main bearings are .004 clearance, not good in my book. Call 440 source. You think they would check them, they told me now I have to get a hold clevite and deal with them.
Re: 440 source bears off [Re: 68dodge] #1954396
11/19/15 05:44 PM
11/19/15 05:44 PM
NE Ohio
DoubleD Offline
DoubleD  Offline
NE Ohio
So is the main clearance off or are the bearing stamped differently than the box ?
Re: 440 source bears off [Re: 68dodge] #1954404
11/19/15 05:59 PM
11/19/15 05:59 PM
West Palm Beach, Florida
Copper Dart Offline
Copper Dart  Offline
popcorn
Common sense, the least common of all the senses.
Mom.
For fear of ridicule, society stifles creativity.
Ricky Valdes
Re: 440 source bears off [Re: 68dodge] #1954414
11/19/15 06:11 PM
11/19/15 06:11 PM
Affton MO
Q
qwkmopardan Offline
qwkmopardan  Offline
Q
Affton MO
.004 on top side but will work fine. I would much rather have .004 than .002.
Re: 440 source bears off [Re: 68dodge] #1954422
11/19/15 06:30 PM
11/19/15 06:30 PM
North Alabama
Monte_Smith Offline
Monte_Smith  Offline
North Alabama
Simple, measure the CRANK. If the crank is within spec, this is not 440 Sources issue. And HOW would they check clearance......they don't have your block.
NOT that I am in any way shape or form, a 440 Source supporter, but how about finding out WHAT the problem is before casting aspersions.
I also agree with above.....004 is NOT too much
Re: 440 source bears off [Re: 68dodge] #1954425
11/19/15 06:35 PM
11/19/15 06:35 PM
usa
lewtot184 Offline
lewtot184  Offline
usa
check the main bores with a dial bore gauge to make sure they're per spec and especially not out of round. the vertical measurement on the last two blocks i checked was awful, the horizontal was in spec; basically egg shaped bores. this will screw up bearing clearance.
Re: 440 source bears off [Re: 68dodge] #1954433
11/19/15 06:56 PM
11/19/15 06:56 PM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
Run it
Re: 440 source bears off [Re: FastmOp] #1954439
11/19/15 07:06 PM
11/19/15 07:06 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Originally Posted By FastmOp
Run it
Exactly.............seen WAY more on record setting Pettis motors.
Re: 440 source bears off [Re: 68dodge] #1954449
11/19/15 07:29 PM
11/19/15 07:29 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
I'm also curious as to how you determined what the clearance is. Obviously parts have to be measured to figure that out. I wouldn't be afraid of .004. Is that what the 440 source said the crank is sized for? Bearings packaged wrong? No other explanation from them other than "Call Clevite"?
Re: 440 source bears off [Re: CMcAllister] #1954484
11/19/15 08:51 PM
11/19/15 08:51 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
I'll give ya $100. for the kit ... CASH. I'll even come and pick it up.
Re: 440 source bears off [Re: Monte_Smith] #1954495
11/19/15 09:03 PM
11/19/15 09:03 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
I agree as well. Bearing clearance is dictated by bearing bore housing dimension, bearing thickness and journal diameter.
Doug
Re: 440 source bears off [Re: lewtot184] #1954514
11/19/15 09:35 PM
11/19/15 09:35 PM
iagree Identify the problem accurately first before trying to correct it thumbs Take the block (and crank)to a good machine shop if you don't have access to a good dial bore gauge and outside micrometer thumbs twocents
I agree with all the other posts about having .004 crank to bearing clearances dry is way better than having .0027 or less dry twocents same thing on the rod clarnaces, a little looser will last a lot longer than a tiny bit to tight will shruggy
Re: 440 source bears off [Re: Cab_Burge] #1954562
11/19/15 10:58 PM
11/19/15 10:58 PM
,Pa.
68dodge Offline OP
68dodge  Offline OP
,Pa.
Took the block and rotating assembly to a machine shop. Block was line bored. They found the same thing, I would like to have.027 clearance than .004.
Re: 440 source bears off [Re: 68dodge] #1954576
11/19/15 11:22 PM
11/19/15 11:22 PM
Fancy Farm Ky
W
wyoming Offline
wyoming  Offline
W
Fancy Farm Ky
There is an old saying, kinda applies to your situation, "If your clearances are just a little loose you'll know it, if the are a little tight everyone will know it" go with what you've got, IMHO
Re: 440 source bears off [Re: 68dodge] #1954578
11/19/15 11:25 PM
11/19/15 11:25 PM
Livonia,MI
1968fury Offline
1968fury  Offline
Livonia,MI
Loose is fast!!!
71 scamp 340 509 cam 456 gear,68 fury1 318 3spd on the tree,50 merc flathead 3x2 3spd w/overdrive
Re: 440 source bears off [Re: 68dodge] #1954582
11/19/15 11:29 PM
11/19/15 11:29 PM
crabman173
crabman173
I for one am GLAD that Source cranks seem to be on the low side--You should be happy--FWIW I am just about done with Clevite--King is the Daddy--and the new "black " bearing they have come out with is the best yet!
Re: 440 source bears off [Re: 68dodge] #1954611
11/20/15 12:01 AM
11/20/15 12:01 AM
usa
lewtot184 Offline
lewtot184  Offline
usa
another thing to try is measuring the thickness of the bearing shells and see if it matches clevite's spec. also, the bearing bores must be measured vertical and horizontal.
Re: 440 source bears off [Re: ] #1954634
11/20/15 12:21 AM
11/20/15 12:21 AM
jacksonville,FLORIDA
slammedR/T Offline
slammedR/T  Offline
I like the aluminum based bearings they had better, the "new black" bearings seem to old school babbit again...
With that said I still love King bearings and will continue to use them in all my builds.
2000 Dakota R/T, 408 magnum, 727, Indy heads
1000cfm 4150 carb, 93 octane fuel.
motor; 10.258 @ 132.78
200 shot; 9.262 @ 144.69
racemagnum
Re: 440 source bears off [Re: 68dodge] #1954672
11/20/15 01:06 AM
11/20/15 01:06 AM
AndyF Offline
AndyF  Offline
Buying a new set of bearings isn't the biggest problem in the world. I just finished a new short block and we didn't use either the rod bearings or the main bearings that came in the stroker kit. Experienced engine builders typically keep several sets of bearings on hand and they'll split sets to get the correct clearance. It is more of a craft than an assembly line.
Re: 440 source bears off [Re: 68dodge] #1954674
11/20/15 01:09 AM
11/20/15 01:09 AM
North Alabama
Monte_Smith Offline
Monte_Smith  Offline
North Alabama
WHY?.........that's too tight for anything other than a stock rebuild and I personally wouldn't even do one of those that tight
