440 source bears off
#1954384
11/19/15 05:14 PM
11/19/15 05:14 PM
Posts: 516 ,Pa.
68dodge
,Pa.
Received my 512 stroker kit. Found out the main bearings are .004 clearance, not good in my book. Call 440 source. You think they would check them, they told me now I have to get a hold clevite and deal with them.
Re: 440 source bears off
[Re: FastmOp]
#1954439
11/19/15 07:06 PM
11/19/15 07:06 PM
Posts: 19,317 State of confusion
Thumperdart
State of confusion
Exactly.............seen WAY more on record setting Pettis motors.
[Re: 68dodge]
#1954449
11/19/15 07:29 PM
11/19/15 07:29 PM
Posts: 11,552 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
I'm also curious as to how you determined what the clearance is. Obviously parts have to be measured to figure that out. I wouldn't be afraid of .004. Is that what the 440 source said the crank is sized for? Bearings packaged wrong? No other explanation from them other than "Call Clevite"?
[Re: CMcAllister]
#1954484
11/19/15 08:51 PM
11/19/15 08:51 PM
Posts: 8,871 Ontario, Canada
Stanton
Don't question me!
Don't question me!
Ontario, Canada
Received my 512 stroker kit. Found out the main bearings are .004 clearance, not good in my book. I'll give ya $100. for the kit ... CASH. I'll even come and pick it up.
[Re: Monte_Smith]
#1954495
11/19/15 09:03 PM
11/19/15 09:03 PM
Posts: 9,835 MI, usa
dvw
MI, usa
Simple, measure the CRANK. If the crank is within spec, this is not 440 Sources issue. And HOW would they check clearance......they don't have your block.
NOT that I am in any way shape or form, a 440 Source supporter, but how about finding out WHAT the problem is before casting aspersions.
I also agree with above.....004 is NOT too much I agree as well. Bearing clearance is dictated by bearing bore housing dimension, bearing thickness and journal diameter. Doug
[Re: lewtot184]
#1954514
11/19/15 09:35 PM
11/19/15 09:35 PM
Posts: 43,163 Bend,OR USA
Cab_Burge
check the main bores with a dial bore gauge to make sure they're per spec and especially not out of round. the vertical measurement on the last two blocks i checked was awful, the horizontal was in spec; basically egg shaped bores. this will screw up bearing clearance. Identify the problem accurately first before trying to correct it Take the block (and crank)to a good machine shop if you don't have access to a good dial bore gauge and outside micrometer I agree with all the other posts about having .004 crank to bearing clearances dry is way better than having .0027 or less dry same thing on the rod clarnaces, a little looser will last a lot longer than a tiny bit to tight will
[Re: 68dodge]
#1954582
11/19/15 11:29 PM
11/19/15 11:29 PM
crabman173
crabman173
I for one am GLAD that Source cranks seem to be on the low side--You should be happy--FWIW I am just about done with Clevite--King is the Daddy--and the new "black " bearing they have come out with is the best yet!
[Re: 68dodge]
#1954611
11/20/15 12:01 AM
11/20/15 12:01 AM
Posts: 3,916 usa
lewtot184
usa
another thing to try is measuring the thickness of the bearing shells and see if it matches clevite's spec. also, the bearing bores must be measured vertical and horizontal.
[Re: ]
#1954634
11/20/15 12:21 AM
11/20/15 12:21 AM
Posts: 733 jacksonville,FLORIDA
slammedR/T
I like the aluminum based bearings they had better, the "new black" bearings seem to old school babbit again... With that said I still love King bearings and will continue to use them in all my builds.
2000 Dakota R/T, 408 magnum, 727, Indy heads 1000cfm 4150 carb, 93 octane fuel. motor; 10.258 @ 132.78 200 shot; 9.262 @ 144.69 racemagnum
[Re: 68dodge]
#1954674
11/20/15 01:09 AM
11/20/15 01:09 AM
Posts: 6,890 North Alabama
Monte_Smith
North Alabama
check the main bores with a dial bore gauge to make sure they're per spec and especially not out of round. the vertical measurement on the last two blocks i checked was awful, the horizontal was in spec; basically egg shaped bores. this will screw up bearing clearance. Identify the problem accurately first before trying to correct it Take the block (and crank)to a good machine shop if you don't have access to a good dial bore gauge and outside micrometer I agree with all the other posts about having .004 crank to bearing clearances dry is way better than having .0027 or less dry same thing on the rod clarnaces, a little looser will last a lot longer than a tiny bit to tight will Took the block and rotating assembly to a machine shop. Block was line bored. They found the same thing, I would like to have.027 clearance than .004. WHY?.........that's too tight for anything other than a stock rebuild and I personally wouldn't even do one of those that tight
