SRT10
#1952703
11/17/15 12:45 AM
11/17/15 12:45 AM
Posts: 1,267 North, Alabama
D-50
North, Alabama
Anybody know what a 2006 SRT10 4 door with a automatic will run in the 1/8. There is one at a local car lot that I am looking at. I need a new tow vehicle.
1.33 60 ft,6.21 at 110.59 in the 1/8, pump gas small block,2950lbs,drag radials,mufflers and driven to track ...
Re: SRT10
[Re: D-50]
#1952938
11/17/15 12:53 PM
11/17/15 12:53 PM
Posts: 13,385 Marion, South Carolina [><]
an8sec70cuda
Not as fast as you'd think for a "500 hp" truck. The Lightning boys around here had a field day w/ those trucks when they first came out. Don't get me wrong, they're a bada$$ looking truck, just be aware.
Re: SRT10
[Re: D-50]
#1953139
11/17/15 05:40 PM
11/17/15 05:40 PM
Posts: 12,423 Kalispell Mt.
HotRodDave
Kalispell Mt.
I have a friend with one and the trans took a dump twice, he quit towing with it and no more trans issues. They say your not supposed to tow with them and I guess that is why. His does have a little bigger cam, CAI and long tube headers fancy exhaust... it is very fast for a 6000 lb or so truck.
Re: SRT10
[Re: Rhinodart]
#1953269
11/17/15 10:00 PM
11/17/15 10:00 PM
D-50
North, Alabama
This one is a automatic with 38000 miles and it came from the factory with a 3 point hitch. I have been towing with a 04 extra cab 3.7 V6 Dakota for 4 years with no problem so you are saying this truck can not with twice the power and torque.
Re: SRT10
[Re: Cheatham]
#1953861
11/18/15 07:40 PM
11/18/15 07:40 PM
Posts: 1,751 Graham, WA
Polarapete
Graham, WA
There are a lot of these trucks in my area right now. The local truck fans prefer the diesels and jacked up 4WD, so the prices are better for the 2WD gas models, both the 10 cylinder and the 5.7 Hemi.
A 2500 model with the 5.7 Hemi will do all the towing I need. Actually my '87 with a fresh LA 360 and 4.10 gears will do nicely.
1986 Dodge Ramcharger 440 2wd, Bracket Racer Under Construction 1998 Ram 2500 QuadCab, new daily driver. 2008 Honda Element 2014 Carry-On 7x14 Cargo Trailer
Re: SRT10
[Re: Cheatham]
#1953929
11/18/15 09:24 PM
11/18/15 09:24 PM
D-50
North, Alabama
the 4 door 10 has a factory 4.56 gear, 48re almost the same as the diesels, drive it right with a trailer and it will do fine, o ya and large brakes, get an sct tuner and lose the cats and it will really wake up, i know i have one. Cheatham, Have you ever made a pass in your truck? I am curious of your before and after modifications.
Re: SRT10
[Re: D-50]
#1953953
11/18/15 10:18 PM
11/18/15 10:18 PM
Posts: 456 corpus christi tex
Cheatham
corpus christi tex
the 4 door 10 has a factory 4.56 gear, 48re almost the same as the diesels, drive it right with a trailer and it will do fine, o ya and large brakes, get an sct tuner and lose the cats and it will really wake up, i know i have one. Cheatham, Have you ever made a pass in your truck? I am curious of your before and after modifications. I bought the truck eary this year and it had all the mods and bolt on one could ask for, Bassani headers true duals with Hooker Max flos dumped before rear axle, 02s are turned off, coil packs, SCT tuner with custom tune, throttle body lowering kit, i never had it to the strip and ive never driven another 10 to compare the difference but it is a fun truck to drive, very responsive and pulls hard, i did pull my car its about 2500lb and trailer is about 800lbs so it not a heavy load, i visit the vtcoa forum lots of good info there.
