I had to be sure #1952293
11/16/15 01:47 PM
11/16/15 01:47 PM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
There were no internal leaks so I pressure tested the block at home.
Re: I had to be sure [Re: Clanton] #1952308
11/16/15 02:22 PM
11/16/15 02:22 PM
Puyallup, WA
StealthWedge67 Offline
Puyallup, WA
Results??? Are we seeing a crack there below the cam journal?
Re: I had to be sure [Re: Clanton] #1952310
11/16/15 02:24 PM
11/16/15 02:24 PM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
No cracks,No leaks Thank you!
Re: I had to be sure [Re: Clanton] #1952311
11/16/15 02:26 PM
11/16/15 02:26 PM
Az
Crizila Offline
Crizila  Offline
Az
Smart move. bow
Fastest 300
Re: I had to be sure [Re: Crizila] #1952316
11/16/15 02:32 PM
11/16/15 02:32 PM
s.w.fl
bonefish Offline
bonefish  Offline
s.w.fl
well, at least you got the block ready for paint grin
Re: I had to be sure [Re: Clanton] #1952318
11/16/15 02:32 PM
11/16/15 02:32 PM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
I got the block re honed after finding this and had to be sure.
Re: I had to be sure [Re: Clanton] #1952331
11/16/15 02:49 PM
11/16/15 02:49 PM
an8sec70cuda Online content
an8sec70cuda  Online Content
Cast iron can be cracked and not leak when pressure tested at room temp.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: I had to be sure [Re: Clanton] #1952388
11/16/15 04:24 PM
11/16/15 04:24 PM
Milwaukee WI
TRENDZ Offline
TRENDZ  Offline
Milwaukee WI
You need to make that available for rent. Nice.
Re: I had to be sure [Re: TRENDZ] #1952431
11/16/15 06:08 PM
11/16/15 06:08 PM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
Thanks! I got the plastic out of the garbage when I was a garbage man,it was a freezer door.
Re: I had to be sure [Re: Clanton] #1952432
11/16/15 06:10 PM
11/16/15 06:10 PM
Tucson AZ,
MadMopars Offline
MadMopars  Offline
Tucson AZ,
Just outta curiosity, what block is that?
[img]https://s9.postimg.cc/6fbjxzfvv/48-2016-_Drag-_Weekend-_Best-_Burnouts-lpr.jpg[/img]
73 GTX *440*727*8 3/4*
69 DART GT *440*4 SPEED*DANA*
73 ROAD RUNNER *451*4 SPEED*DANA*
64 F100 *383*4 SPEED*9"*
75 DODGE D300 *440*4 SPEED*DANA*
99 DODGE RAM 3500 4X4 DUALLY... ON 38"s
Re: I had to be sure [Re: MadMopars] #1952452
11/16/15 06:47 PM
11/16/15 06:47 PM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
Koleno block #33
Re: I had to be sure [Re: Clanton] #1952459
11/16/15 06:53 PM
11/16/15 06:53 PM
malvern, ohio
3
3ddart Offline
3ddart  Offline
malvern, ohio
Like chip said just air at room temp may not show, been there had that happen. You may want to do add hot water to the test!
can 13
Re: I had to be sure [Re: 3ddart] #1952468
11/16/15 07:02 PM
11/16/15 07:02 PM
corpus christi tex
Cheatham Offline
Cheatham  Offline
corpus christi tex
Very true need to get it heated up as if it were running
Re: I had to be sure [Re: Clanton] #1952476
11/16/15 07:23 PM
11/16/15 07:23 PM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
Now that I tested it I am confident the Moroso sealer sealed any leaks.You are welcome to explain how you would heat the block tho.I did have a plan.
Re: I had to be sure [Re: Clanton] #1952630
11/16/15 11:30 PM
11/16/15 11:30 PM
Belpre,Ohio
CHAPPER Offline
CHAPPER  Offline
Belpre,Ohio
Here is what I made to find a 'hot only' leak on a complete engine. I'm sure you can do something similar with the empty block after a little thought.
If you like drag racing, support your local track.
Re: I had to be sure [Re: Clanton] #1952669
11/17/15 12:12 AM
11/17/15 12:12 AM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
Wow that is quite a getup.I have a 125,00 BTU heater to bring the block to temp and then pour hot water in and seal it.I would use a temperature gun to check things.
Re: I had to be sure [Re: Clanton] #1952716
11/17/15 01:01 AM
11/17/15 01:01 AM
malvern, ohio
3
3ddart Offline
3ddart  Offline
malvern, ohio
I had a cylinder in a 360 block that looked like yours, but couldn't see the problem. I ended up putting some water in the block and took a propane torch to the rust area and low and behold it started blowing steam as there was a pinhole in the cylinder wall
can 13
Re: I had to be sure [Re: 3ddart] #1952863
11/17/15 11:30 AM
11/17/15 11:30 AM
Something like this is what I would do first. If that didn't show anything, then I'd try something a little more complex like the pictures w/ the copper worm.
CHIP
Re: I had to be sure [Re: Clanton] #1953582
11/18/15 11:26 AM
11/18/15 11:26 AM
Mass.
8
80fbody Offline
80fbody  Offline
Mass.
Wouldn't it be easier to just sleeve that cylinder and have no worries then try to fab that crazy heated setup?
Re: I had to be sure [Re: Clanton] #1953728
11/18/15 03:25 PM
11/18/15 03:25 PM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
There are many ways to test depending on what you have.
https://www.youtube.com/watch?v=c6xrnfQGdko
She is clean,dry.
