Re: I had to be sure
[Re: Clanton]
#1952308
11/16/15 02:22 PM
11/16/15 02:22 PM
Posts: 4,319 Puyallup, WA
StealthWedge67
Puyallup, WA
Results??? Are we seeing a crack there below the cam journal?
[Re: Clanton]
#1952331
11/16/15 02:49 PM
11/16/15 02:49 PM
Posts: 13,374 Marion, South Carolina [><]
an8sec70cuda
Cast iron can be cracked and not leak when pressure tested at room temp.
[Re: Clanton]
#1952388
11/16/15 04:24 PM
11/16/15 04:24 PM
Posts: 2,540 Milwaukee WI
TRENDZ
Milwaukee WI
You need to make that available for rent. Nice.
[Re: TRENDZ]
#1952431
11/16/15 06:08 PM
11/16/15 06:08 PM
Posts: 4,489 northern,Ohio,USA
Clanton
northern,Ohio,USA
You need to make that available for rent. Nice. Thanks! I got the plastic out of the garbage when I was a garbage man,it was a freezer door.
[Re: Clanton]
#1952459
11/16/15 06:53 PM
11/16/15 06:53 PM
Posts: 1,466 malvern, ohio
3ddart
malvern, ohio
Like chip said just air at room temp may not show, been there had that happen. You may want to do add hot water to the test!
can 13
[Re: 3ddart]
#1952468
11/16/15 07:02 PM
11/16/15 07:02 PM
Posts: 456 corpus christi tex
Cheatham
corpus christi tex
Like chip said just air at room temp may not show, been there had that happen. You may want to do add hot water to the test! Very true need to get it heated up as if it were running
[Re: Clanton]
#1952630
11/16/15 11:30 PM
11/16/15 11:30 PM
Posts: 3,410 Belpre,Ohio
CHAPPER
Belpre,Ohio
Here is what I made to find a 'hot only' leak on a complete engine. I'm sure you can do something similar with the empty block after a little thought.
If you like drag racing, support your local track.
[Re: Clanton]
#1952716
11/17/15 01:01 AM
11/17/15 01:01 AM
3ddart
malvern, ohio
I had a cylinder in a 360 block that looked like yours, but couldn't see the problem. I ended up putting some water in the block and took a propane torch to the rust area and low and behold it started blowing steam as there was a pinhole in the cylinder wall
can 13
[Re: 3ddart]
#1952863
11/17/15 11:30 AM
11/17/15 11:30 AM
an8sec70cuda
I had a cylinder in a 360 block that looked like yours, but couldn't see the problem. I ended up putting some water in the block and took a propane torch to the rust area and low and behold it started blowing steam as there was a pinhole in the cylinder wall Something like this is what I would do first. If that didn't show anything, then I'd try something a little more complex like the pictures w/ the copper worm.
