Is it possible to buy just one b engine cam bearing?
#1951407
11/15/15 03:07 AM
11/15/15 03:07 AM
Posts: 4,384 Madison Wi
NTOLERANCE
Madison Wi
Messed up the rear bearing during install
Did some searching. Can't find just one
I'll buy a full set again but anyone know how to get just the rear most bearing ?
Re: Is it possible to buy just one b engine cam bearing?
[Re: NTOLERANCE]
#1951543
11/15/15 12:41 PM
11/15/15 12:41 PM
NTOLERANCE
Madison Wi
Thanks. I'll try a few. At least it's an easy one to get at
[Re: NTOLERANCE]
#1951916
11/15/15 09:49 PM
11/15/15 09:49 PM
Posts: 905 SD
zrxkawboy
SD
Find the individual part number in a Chrysler parts catalog, then search for that number at the NOS suppliers like Deception Pass, etc.
It's Swifty! Swifty, you toad sucker!
[Re: NTOLERANCE]
#1951944
11/15/15 10:22 PM
11/15/15 10:22 PM
NTOLERANCE
Madison Wi
Well I've checked several. No know has single part numbers
If anyone has an old part number for the rear most bearing I would appreciated it if it could be posted
[Re: NTOLERANCE]
#1951957
11/15/15 10:42 PM
11/15/15 10:42 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
Well, engine would be nice to know. I could assume you're working on a 1938 218 flathead six, but you probably wouldn't need that bearing.
[Re: Supercuda]
#1952124
11/16/15 02:04 AM
11/16/15 02:04 AM
Posts: 588 Franklin, TN
23T Hemmee
Franklin, TN
Well, engine would be nice to know. I could assume you're working on a 1938 218 flathead six, but you probably wouldn't need that bearing. Maybe the title of the thread will give you a clue.....
[Re: NTOLERANCE]
#1952135
11/16/15 02:25 AM
11/16/15 02:25 AM
Posts: 905 SD
zrxkawboy
SD
Try 1821775. Deception Pass shows them for $10 each.
[Re: NTOLERANCE]
#1952218
11/16/15 11:01 AM
11/16/15 11:01 AM
Posts: 905 SD
zrxkawboy
SD
Hey, just giving the man what he asked for.
