Is it possible to buy just one b engine cam bearing? #1951407
11/15/15 03:07 AM
11/15/15 03:07 AM
Madison Wi
NTOLERANCE Offline OP
Madison Wi
Messed up the rear bearing during install
Did some searching. Can't find just one
I'll buy a full set again but anyone know how to get just the rear most bearing ?
Re: Is it possible to buy just one b engine cam bearing? [Re: NTOLERANCE] #1951510
11/15/15 11:53 AM
11/15/15 11:53 AM
Cleveland Ohio
sportfury70 Offline
sportfury70  Offline
Cleveland Ohio
I had same issue 20+ years ago in high school. Went to auto parts store & was able to get just the 1 bearing. There should be a part number for each bearing.
Re: Is it possible to buy just one b engine cam bearing? [Re: NTOLERANCE] #1951543
11/15/15 12:41 PM
11/15/15 12:41 PM
Madison Wi
Madison Wi
Thanks. I'll try a few. At least it's an easy one to get at
Re: Is it possible to buy just one b engine cam bearing? [Re: NTOLERANCE] #1951598
11/15/15 01:38 PM
11/15/15 01:38 PM
AndyF Offline
AndyF  Offline
They each have individual part numbers from Mopar but they might not be available anymore. I used to have boxes of individual cam bearings but I think I got rid of all that stuff.
Re: Is it possible to buy just one b engine cam bearing? [Re: NTOLERANCE] #1951916
11/15/15 09:49 PM
11/15/15 09:49 PM
SD
Z
zrxkawboy Offline
zrxkawboy  Offline
Z
SD
Find the individual part number in a Chrysler parts catalog, then search for that number at the NOS suppliers like Deception Pass, etc.
It's Swifty! Swifty, you toad sucker!
Re: Is it possible to buy just one b engine cam bearing? [Re: NTOLERANCE] #1951944
11/15/15 10:22 PM
11/15/15 10:22 PM
Madison Wi
Madison Wi
Well I've checked several. No know has single part numbers
If anyone has an old part number for the rear most bearing I would appreciated it if it could be posted
Re: Is it possible to buy just one b engine cam bearing? [Re: NTOLERANCE] #1951957
11/15/15 10:42 PM
11/15/15 10:42 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Well, engine would be nice to know. I could assume you're working on a 1938 218 flathead six, but you probably wouldn't need that bearing.
Don't be the exception.
Re: Is it possible to buy just one b engine cam bearing? [Re: NTOLERANCE] #1951983
11/15/15 11:11 PM
11/15/15 11:11 PM
chicagoland,usa
buildanother Offline
chicagoland,usa
Although I think I have a broken set with rear bearing around here somewhere, if I were you I would probably invest in a new set by this time. Last ones I purchased (set of 5) were Clevites and less than 20 bux IIRC.
Re: Is it possible to buy just one b engine cam bearing? [Re: Supercuda] #1952124
11/16/15 02:04 AM
11/16/15 02:04 AM
Franklin, TN
23T Hemmee Offline
23T Hemmee  Offline
Franklin, TN
Maybe the title of the thread will give you a clue.....
Ronny
6.789 @ 198.63 **.956 Brand New 60'***
4.17@ 169 1/8th mile
John 14:6
https://www.youtube.com/watch?v=TUku_hjYRh8
Re: Is it possible to buy just one b engine cam bearing? [Re: NTOLERANCE] #1952135
11/16/15 02:25 AM
11/16/15 02:25 AM
SD
Z
zrxkawboy Offline
zrxkawboy  Offline
Z
SD
Try 1821775. Deception Pass shows them for $10 each.
Re: Is it possible to buy just one b engine cam bearing? [Re: NTOLERANCE] #1952214
11/16/15 10:48 AM
11/16/15 10:48 AM
md
mopars4ever Offline
mopars4ever  Offline
md
$10 for the bearing then $10 for shipping. Makes no sense not to just buy a whole set for $25-$30 and be done with it.
Re: Is it possible to buy just one b engine cam bearing? [Re: NTOLERANCE] #1952218
11/16/15 11:01 AM
11/16/15 11:01 AM
SD
Z
zrxkawboy Offline
zrxkawboy  Offline
Z
SD
Hey, just giving the man what he asked for.
Re: Is it possible to buy just one b engine cam bearing? [Re: NTOLERANCE] #1952241
11/16/15 11:49 AM
11/16/15 11:49 AM
md
mopars4ever Offline
mopars4ever  Offline
md
Wasn`t trying to be critical. I was just saying to the OP why not just get a new set. It`s not like they are $100 or so.
Re: Is it possible to buy just one b engine cam bearing? [Re: mopars4ever] #1952281
11/16/15 01:24 PM
11/16/15 01:24 PM
dogdays Offline
dogdays  Offline
Guys, which cam bearing is the best? I believe there is one company making seamless cam bearings.
R.
