E body, where can I get screw for turn signal lever #1951352
11/15/15 01:09 AM
11/15/15 01:09 AM
N.E. Ohio
K
KillerBee Offline OP
K
N.E. Ohio
Putting the steering column back together on the wife's Challenger and I noticed the long screw that holds the turn signal lever in is a little boogered up.
Anyone know where I can get one or what size it is?
Thanks.up
Re: E body, where can I get screw for turn signal lever [Re: KillerBee] #1951393
11/15/15 02:24 AM
11/15/15 02:24 AM
You might take it with you to Ace hardware, they have the most extensive of nuts/bolts/screws by far of any store I've ever run into
Re: E body, where can I get screw for turn signal lever [Re: KillerBee] #1951412
11/15/15 03:18 AM
11/15/15 03:18 AM
Jefferson State
srt Offline
ESYC
srt  Offline
ESYC
Jefferson State
I've found some specialized fasteners at fastenall. Their online catalog is pretty easy to navigate.
Re: E body, where can I get screw for turn signal lever [Re: KillerBee] #1951429
11/15/15 04:43 AM
11/15/15 04:43 AM
Medina, Ohio
HEMICUDA Offline
HEMICUDA  Offline
Medina, Ohio
I have an extra you're welcome to.
Re: E body, where can I get screw for turn signal lever [Re: HEMICUDA] #1951716
11/15/15 04:41 PM
11/15/15 04:41 PM
N.E. Ohio
K
K
N.E. Ohio
Thanks for the offer. beer
I'm going to take it to my local industrial fastener supply house and see if they can identify and match it.
If I don't have any luck I'll be in touch.
Re: E body, where can I get screw for turn signal lever [Re: RapidRobert] #1951752
11/15/15 05:42 PM
11/15/15 05:42 PM
Graham, WA
P
Polarapete Offline
Polarapete  Offline
P
Graham, WA
Ace is the place, even though they are only open 9 to 6 in Graham.
1986 Dodge Ramcharger 440 2wd, Bracket Racer Under Construction
1998 Ram 2500 QuadCab, new daily driver.
2008 Honda Element
2014 Carry-On 7x14 Cargo Trailer
