E body, where can I get screw for turn signal lever
#1951352
11/15/15 01:09 AM
11/15/15 01:09 AM
Posts: 6,497 N.E. Ohio
KillerBee
N.E. Ohio
Putting the steering column back together on the wife's Challenger and I noticed the long screw that holds the turn signal lever in is a little boogered up. Anyone know where I can get one or what size it is? Thanks.
Re: E body, where can I get screw for turn signal lever
[Re: KillerBee]
#1951393
11/15/15 02:24 AM
11/15/15 02:24 AM
RapidRobert
You might take it with you to Ace hardware, they have the most extensive of nuts/bolts/screws by far of any store I've ever run into
[Re: HEMICUDA]
#1951716
11/15/15 04:41 PM
11/15/15 04:41 PM
KillerBee
N.E. Ohio
I have an extra you're welcome to. Thanks for the offer. I'm going to take it to my local industrial fastener supply house and see if they can identify and match it. If I don't have any luck I'll be in touch.
[Re: RapidRobert]
#1951752
11/15/15 05:42 PM
11/15/15 05:42 PM
Posts: 1,751 Graham, WA
Polarapete
Graham, WA
You might take it with you to Ace hardware, they have the most extensive of nuts/bolts/screws by far of any store I've ever run into Ace is the place, even though they are only open 9 to 6 in Graham.
1986 Dodge Ramcharger 440 2wd, Bracket Racer Under Construction 1998 Ram 2500 QuadCab, new daily driver. 2008 Honda Element 2014 Carry-On 7x14 Cargo Trailer
